There's a simple way to delete all stream data entries, but that doesn't seem to delete the entry times; a dashboard widget reading an apparently empty stream still sets the axis times (whereas an entirely new and unused stream has no times set on the axis, as expected).
Is there a way around this? Really it's only useful for debugging, but it's handy then.
Thanks - Will
How are you deleting the stream data?
Components => right click on selected stream => delete all time series stream data
As far as I can tell, that's the only way to completely delete a streams contents, while keeping the stream.
Will
2968 3 3
