Dashboard widget Y axis444
seckford private msg quote post Address this user | plus 1 0 |
The Dashboard graphs adjust their Y axis range to match the current data; is there a way of setting a fixed range? Thanks - Will |
MThomas private msg quote post Address this user | plus 1 0 |
Should be able to go into the graph widget settings->Axes-> set the min and max. | ||
Yes, that seems to work - thanks. Will |
MikeMills private msg quote post Address this user | plus 1 0 |
I'll add that if either or both of the axis min/max are left blank, they are automatically adjusted. So you can just set the min and leave the max blank and have it auto-set if that is what you need. | ||
