Graham private msg quote post Address this user
Greetings
any body know why I get no response from the top right hand controls of a widget " < > + - refresh options X "
Is it only a specific widget that has that issue?
Does it go away if you add the same widget to a new dashboard?
Does it go away if you do an hard refresh (F5)?
Usually this indicates an bug in the client java script logic running in the browser.
Thanks for the reply Mike,
I,m running Lenovo I5, Windows 7 upgraded to 10, and Chrome Browser.
to answer your queries:- no response to F5, happens across all widgets, adding new dashboard with same widget gives same issue.
Reproduced it. Seems to be a problem with a newer Chrome version. It worked in IE. We'll try and get a patch put together.
Patch applied. Hit F5 to refresh the browser.
Post 6 • IP   flag post
2589 6 6
destitute
