Sum of stream over long period of time405
I have a stream whose value is either 0 or 1. Basically, it indicates if the associated motor was running or not. The stream data gets pushed once per minute. I need to know the total run time over a 2 month period. I don't have a base cycle or rollup and could certainly add those settings, including a "month" in the roll-ups. However, I'm wondering if there's another "better" way to do this.
[edit] So...I defined a base cycle of 1 minute and rollups of: hours, days and months and it seems to work well. That being said the stream viewer looks a bit strange for the one ending date, so I'm attaching a screen capture of it.
[edit] By the way, this capability is AMAZING!!! You just gotta love Grovestreams!
Glad you found a way!
The time is displayed in compact format by default. Compact format will trim off the year, month, day if the time is the current day.
You can change that behavior in your user profile (click your name):
2969 2 2
