Having trouble with webhook,particle photon452
orbitcoms private msg quote post Address this user | plus 1 0 |
I followed the setup steps to create a webhook for my particle device. I already have a Grovestream account with company created. When I TEST the webhook after creating the integration, I get ERROR 400 all the time. I tried both {{SPARK_SORE_ID}} and {{PARTICLE_CORE_ID}} - not sure which to use because Spark.Publish was changed recently to Particle.Publish. The data is getting to the PArticle IO console ok. Every time I see the temperature the next record is "error status 400 from GroveStreams.com". Thanks Regards Dave |
ctmorrison private msg quote post Address this user | plus 1 0 |
Can you please show your Particle.publish() call that you're using to call the webhook? | ||
Thanks for your response. I checked the publish and I had the topic set to "temp/1" but in webhooks I had event set to "Temperature". I changed event to "temp/1" and now I get no errors. Regards Dave |
