Trouble with dashboard widget settings228
JChristensen private msg quote post Address this user
This occurs with Firefox but not with Chrome. It occurs with new or existing dashboards. Steps to reproduce below. Step 5 can be eliminated but the results are the same (this is just the way I initially discovered it). Refreshing the page clears the problem, but I didn't find anything else short of that, that did.
1. Create a new dashboard.
2. Add a line chart.
3. Drag any data stream to the chart.
4. Save the dashboard.
5. Click Change Appearance.
6. Click Options > Settings on the chart widget.
7. Click OK or Cancel.
8. Click Options > Setting again and the the Settings dialog does not appear.
We had another user report this via email too. We just applied a patch that should fix it.
Did F5 and refreshed the page but still seeing the same behavior. Has the patch been rolled out?
Yes, but it appears we fixed a different issue. Digging into this one now...
Patch applied.
Looks fine now, thank you!
3070 6 6
