Dashboard Stream Swapping233
We have created a stream replacement tool for dashboards.
Many times a large dashboard is setup with many unique visual settings per stream. Users would like to copy the dashboard but just replace the streams while preserving all of the settings for each stream.
This tool allows for that.
1. Open the dashboard and select Change Appearance
2. Select the Maintenance pane on the left and click the Change Streams button
3. Change the component and stream IDs to the new IDs that will replace the existing streams or just leave the existing IDs if you do not wish to swap that stream out
4 Click the Change Streams button to swap out the streams
Allows the changing of stream groups too!
Seems like this is maxed out at about 75 streams in your dashboard. If you have more than that you need to do it the old-fashioned way.
How is it maxed out? Are you seeing an error?
Click the Change Streams button and you get this response. Only seems to be an issue when many streams (I figure about 75) are in the dashboard
Failed to communicate with the server.
Details:
Status: 414
Status Text: Request-URI Too Large
The browser is restricting the size of the URL being used during the stream swap process. IE seems to have the lowest allowed URL size. Is that what you're using? If so, try Chrome or Firefox.
3070 5 5
