Steel Series - time window238
We love the steel series widgets and use them on nearly every Dashboard. However, one downside is that they show the most recent value, no matter how old it is. Whereas this may often be appropriate, we have no way of knowing if this is a recent (timely) data point or something quite old due to data no longer being pushed by a device.
Would it be possible to add an attribute that would allow us to blank out the field if it's older than N seconds (I know you like working in seconds!). This would allow us to blank it out if we hadn't received data within, say, the last hour.
We've wanted this in-house too. We'll put it on the short list.
Three new settings:
* Threshold Latency Color: The color to change to when Threshold Latency is reached.
* Threshold Latency - Set to Value : An optional value the widget will display when Threshold Latency is reached. The gauges do not support just being blank so a value needs to be set.
* Threshold Latency: The number of seconds that must elapse since the stream had values added to it before the latency threshold was reached.
The example below shows values set to 10 and the color set to white when a 15 second latency threshold is reached.
The latency check only occurs when the widget is manually refreshed or each time automatic polling occurs.
Great!!! Thanks for adding this feature. It will reduce confusion when looking at some of our dashboards.
3070 4 4
