We've added the ability to display each axes within its own pane on the same graph while using the same navigator bar for all panes:
We've added three new axes settings to configure your chart for multiple panes:
* Line Width: The width of the Y axis line.
* Height: The height of the Y axis. If it's a number, it is interpreted as pixels. If it's a percentage string, it is interpreted as percentages of the total plot height.
* Top: The top position of the Y axis. If it's a number, it is interpreted as pixel position relative to the chart. If it's a percentage string, it is interpreted as percentages of the plot height, offset from plot area top.
Phill private msg quote post Address this user
I am not getting the same results as your image... all of my graphs are stacked in the top run with nothing in the bottom 2 - what am I missing here?
Ignore... found it in the data settings...
3071 5 5
