Events not firing -- Time Filter issue?301
We added a time filter to events on one of our organizations and since then have not seen any events (SMS actions) firing. We've successfully used Time Filters in the past. I'm wondering if something has changed.
We haven't changed anything in that area for some time. If you can setup a reproducible use case then we can take a look at it.
For example, create a test component with a stream with events including a time filter. Then manually set some values in the stream and see whether the event fails to start.
One of our live sites is sending in stream data that includes values that should trigger an event. The organization is Pender County School District and the component is Heidi Trask Chiller 1. The stream being monitored is Circuit 2 Alarm. We should have received a SMS at 13:48 today.
Found an issue with Regular Streams and Events with a Time Filter that is including all time spans. Applied a patch. Let us know if you still experience any issues around this.
Already getting alerts! Thanks for the quick fix!!!
3071 5 5
