Component, Dashboard, Map Copy Improvements347
* Multiple copies can now be made at one time * Folders, along with their contents, can now be copied * Derived stream references can be adjusted within a copy. If a folder contains many components and some of those components contain expression derived streams that reference streams that are part of the copy, the newly copied derived streams can be made to reference the other newly copied streams (not the streams outside the copy). This improves reusing complex component cluster analytics within an organization. Try to organize components that reference other components under the same folder so that this new feature can be applied as your environment grows. For example, you may have modeled a large campus building. As you add new buildings, just copy a campus building folder while preserving expression stream variable references to duplicate your building model. ![]() |
