* Added Display Filters back to Notification lists
Post 226 IP   flag post
* Added Delete to content permissions. Previously, the Write permission determined if a user had rights to Delete an item. The new Delete permission defaults to the Write permission setting for items that had permissions configured.
* Improved the "Are you sure you want to delete ..." message to include more information about what's being deleted. Improved message:
Post 227 IP   flag post
Patch Applied:
* Fix for a derived stream's dependent being deleted and causing issues with editing and saving the component that the derived stream belongs to. The deleted stream should still show up in the list with the name of 'MISSING' and give the modeler the chance to fix it:
* Fix for a derived stream precedent detection for a stream that originally wasn't a derived stream during the first save but was after that.
* Fix for "Move to.." in content folders. The move to folder had to have been expanded (lazy fetched) or the move to would fail.
* Remove spell check for several GS SQL Editors
* Fixed GS SQL Test window's Display Filter
* Added startDate and endDate to stream's quick view:
Post 228 IP   flag post
* Applied a patch for email addresses with special characters like the plus sign
* Starting to drop explore and learning videos
Post 229 IP   flag post
* New real-time derivation enhancement
Post 230 IP   flag post
1. Added "Copy To"
a. Copy multiple folders and components to other multiple folders.
b. Copy streams to other components
c. Copy stream data to other streams while doing a stream type conversion and reconcile
2. Improved delete confirmation
3. Ensure all trees visually indicated the same change. For example, if a component is renamed in one tree, it is renamed in the search and picker trees
4. Tree bug fixes such as copying to a folder that no longer existed
Learn about the new features in this awesome video:
Post 231 IP   flag post
* Stream Derivation Dependency Reconcile Lock option fix
* Added Stream .csv Import/Export
Stream Viewer Export Entire Stream in .csv GS Format:
Stream Viewer Import Stream Window. Supports both stream exports formats plus more date formats:
Added Import Export options to right-click menu in GS Studio and in the new dashboard designer site:
Post 232 IP   flag post
* New Dashboard Designer Announcement
More information in this video:
Post 233 IP   flag post
* Stream & Component CSV Import/Export Enhancements
* Stream Derivation By Expression Diagnostics and Drill-Into Functionality.
See this video for details:
Post 234 IP   flag post
* Added support for Monnit Rules Webhook. In beta.
* Added Manual Derive menu options and buttons. Up to 20 precedent streams of the derived stream will be derived immediately too.
** The From dependent changes forward option is for impatient users. It will run normal derivation immediately vs waiting a minute or two for the job servers to run it. It will only process dirty time ranges - not the whole stream.
** The All option will delete all of the derived stream's data and re-derive all of it immediately.
*Added shortcut buttons to the Drill Through window grid columns:
** Re-derive
** Open Diagnostic Window
** Expand Rollup Cycle
* The Expand button (1) will open a new window with a new column (2) that includes the previous cycle's values. This will help to see how a rollup value was calculated within a derived stream
* Added a Diagnostic Tips button to the bottom of the Derivation Diagnostics window. Brings up a window of troubleshooting tips.
* The Run Derivation options require Execute rights.
* The Diagnostic and Drill Into windows require Read rights.
Post 235 IP   flag post
* Support for Big Strings
* Improved Derivation Expression and GS SQL Editors
* Better GS SQL Error Messages
* Several GS SQL fixes
* Many Studio scrollbar and splitter issues fixed
* New JSON and CSV string parsing functions
Post 236 IP   flag post
* Added GS SQL INSERT statement
* Added GS SQL WITH statement
* Added GS SQL CASE statement
* Added GS SQL SUBSTR function
* GS SQL supports multiple statements in one call. Separated by semicolons
* GS SQL LIKE also uses % and _ as wildcards now
* GS SQL IF supported. Same as IIF
* GS SQL MIN and MAX aggregation can also be treated as functions now
* New Derivation Functions
** avgNg(x1, previousSampleCount [, respectTod] [, maxLookBackIntvls] [, maxLookBackIncludesFilteredIntvls] [, minSampleCount]) Calculates the rolling average while ignoring gaps. Can respect Time-of-day.
** avgPeaksNg(x1, previousSampleCount [, respectTod] [, maxLookBackIntvls] [, maxLookBackIncludesFilteredIntvls] [, minSampleCount]) Just like avgNg but returns the Maximum sample instead of the average.
** avgNgForward(x1, futureSampleCount [, respectTod] [, maxLookForwardIntvls] [, maxLookForwardIncludesFilteredIntvls] [, minSampleCount])
** ruPercentile(x1, percentileDecimal) Calculates the roll-up percentile
The derivation functions have been in use for a couple of years. They are highly complex and had many issues early on so we were reluctant to expose them. They are stable now, but results should be verified as you introduce them into your logic.
Adding INSERT to GS SQL will solve many use cases such as Importing and using GS SQL as a derived stream source. Just use an INSERT within a Scheduled Saved Query and you now have one or more derived streams from GS SQL. Very powerful.
Adding CASE and WITH and other SQL features makes GS SQL easier to read and more compatible with other SQL implementations. This is important as AI can be asked to generate SQL statements and it will tend to use common SQL keywords.
Give it a try. Ask your favorite AI: "Generate a grovestreams.com GS SQL statement that does XXX"
GS SQL will become more important as AI becomes more of a "user/operator" of platforms and not just a "really good answer bot". SQL will be one of many common APIs that AI will use to access data.
Post 237 IP   flag post
* Connectors: Provides the capability to accept, parse, modify data from external systems or webhooks. The GS SQL Connector is available for all pricing plans.
* Re-authenticating from one browser tab will auto-reauth all other open tabs
* Added Variables to GS SQL: Needed for Connector project
* Dashboard Search bug fixes
Post 238 IP   flag post
* Added Report OData connector for external reporting capabilities. Requires GS SQL: OData Connector
Post 239 IP   flag post
Starting deployment of AI Forecasting across all servers. Expecting no issues, but it has some risk.
This will take a few hours as we deploy, update the store and run some tests.
Post 240 IP   flag post
Deployment of AI Forecasting Models is finished. We will be continuing testing throughout the day.
* Forecasting is available for all pricing models except the Free plan. Forecasting is free for now, but we will be charging by CPU time in the future.
* Each Model Training currently utilizes several cores on one server. We will be adding GPUs and multiple server processing (per model) as customers require more hardware for intensive training.
* Models Supported:
- TFTModel (Temporal Fusion Transformer - Deep Learning)
- NBEATSModel (Deep Learning)
- ARIMA
- Prophet
- TCNModel (Temporal Convolutional Network - Deep Learning)
- TransformerModel (Deep Learning)
- ExponentialSmoothing
- RNNModel (Recurrent Neural Network - Deep Learning)
* Quick Forecast - right click a stream and choose Quick Forecast...
*Forecasting mainly applies to Interval streams. Prophet supports regular streams, but we haven't tested regular (or random) stream forecasting yet.
* New Model Editor and Wizard - See Forecasting Help Page
* New Stream Correlation Detection wizard (see Forecasting Help Page):
Post 241 IP   flag post
* Fix for Tools right click menu (properties/security) not appearing
* Fix for data stream list not appearing while editing time-series grid within the dashboard editor
* Fix for OData reporting adapter "Null Pointer" error during "Load Data" in PowerBuilder BI
* Fix for historical update detection for derivation
* Fix for exception thrown for GS SQL queries involving point streams
* Fixed exception thrown for GS SQL Subquery Alias usage in WHERE clause
* Fixed GS SQL Exception for IIF clause
* Fixed Copy data To regular stream from interval stream exception
Post 242 IP   flag post
* Fix for interval and regular stream editors for string datatypes.
Post 243 IP   flag post
* Re-configuring the GS email and Amazon SES settings to remove the 'Unverified' notice that some providers, like MS Outlook, are displaying. We've made a round of changes and will be testing and tweaking over the next day or two.
Post 244 IP   flag post
* GS Forecasting Video
Post 245 IP   flag post
July 25th, 2025, 12:36 pm to 1:44 pm Central Time:
Web servers responses became slow and many requests timed out. This was due to a single store server becoming very slow.
Post 246 IP   flag post
* Added the ability for Organization administrators to display a message to organization users
* Allow dashboard with classic form widgets to be displayed and saved
* Fixed 'Open' menu item within dashboard tree
* Fixed Steel Series Radial widget min/max indicators
Post 247 IP   flag post
* The new display user message enhancement is displaying "Organization with store identifier 'x' does not exist in the store."
The organization does exist. We are investigating and will apply a new patch.
Post 248 IP   flag post
* Fixed "Organization with store identifier 'x' does not exist in the store." message appearing. The organization really did exist and the message should not have appeared.
Post 249 IP   flag post
* User security rights can now be transferred to another user during the removal of the user from an organization
* Fixed issue preventing derivation dependent change detection during the saving of a component's auto Re-derive check.
* Opening two streams in the stream viewer and then exporting not the first stream will always export the first stream. Fixed.
* Execute Query from right clicking a Query in Tools was not working. Fixed.
Post 250 IP   flag post
Large Update for the new AI Assistant (coming this week) - Monitor your imports and GS SQL executions for any errors
* Many SQL improvements: Better support for Alias, Several performance improvements (faster batch sample fetches, intelligent "bushy" joins), new tables (activeevent, usernotification, systemnotification, jobnotification , improved error messages, Count(*) and Select * supported. Fixes for mixed stream types (point, regular, interval) queries.
* Updgraded our JSON and CSV libraries for better special character handling
* Upgraded our math library
* New AI Assistant and AI dashboard widget
-- More announcements on this in the next day or two (it's scary good)
-- Goal is to test and stabilize after these big changes.
Post 251 IP   flag post
* The AI assistant beta is available. You have to go to your favorite LLM API website (Google Gemini, Anthropic, OpenAI, or xAI) add some credits $$, get an API key and enter it into your grovestreams organization - Admin - settings. xAI grok 4 fast with reasoning (for the brain) and grok 4 fast (for the minion) are highly recommended. They were just released, are showing some of the best results and are not expensive.
* The GS AI assistant is scary good if you have a pricing plan that includes GS SQL. It will have access to everything in your organization that the calling user has. Otherwise it will not have access to stream data, active events and notifications.
* Much more information on the AI assistant is coming
* Patch applied that fixes the Digi gateway issue resulting from last weekend's large update.
Post 252 IP   flag post
* The AI assistant has a security Group Capability. If you are not the organization owner, then a security group will need to be edited and the AI Assistant capability has to be engaged.
* For example, edit the Administrator group and enable AI Assistant
* The AI will know what you have selected in the Studio left trees. Select a stream and prompt "Analyze this stream, look for issues, tell me how it can be improved".
Post 253 IP   flag post
* More about the AI Assistant and How to Set it up Here
Post 254 IP   flag post
* Multiple GS Query Editor and Tester windows can be open at the same time now
* More AI Assistant improvements
Post 255 IP   flag post
3071 264 30
