Large Update for the new AI Assistant (coming this week) - Monitor your imports and GS SQL executions for any errors
* Many SQL improvements: Better support for Alias, Several performance improvements (faster batch sample fetches, intelligent "bushy" joins), new tables (activeevent, usernotification, systemnotification, jobnotification , improved error messages, Count(*) and Select * supported. Fixes for mixed stream types (point, regular, interval) queries.
* Updgraded our JSON and CSV libraries for better special character handling
* Upgraded our math library
* New AI Assistant and AI dashboard widget
-- More announcements on this in the next day or two (it's scary good)
-- Goal is to test and stabilize after these big changes.
Post 251 IP   flag post
* The AI assistant beta is available. You have to go to your favorite LLM API website (Google Gemini, Anthropic, OpenAI, or xAI) add some credits $$, get an API key and enter it into your grovestreams organization - Admin - settings. xAI grok 4 fast with reasoning (for the brain) and grok 4 fast (for the minion) are highly recommended. They were just released, are showing some of the best results and are not expensive.
* The GS AI assistant is scary good if you have a pricing plan that includes GS SQL. It will have access to everything in your organization that the calling user has. Otherwise it will not have access to stream data, active events and notifications.
* Much more information on the AI assistant is coming
* Patch applied that fixes the Digi gateway issue resulting from last weekend's large update.
Post 252 IP   flag post
* The AI assistant has a security Group Capability. If you are not the organization owner, then a security group will need to be edited and the AI Assistant capability has to be engaged.
* For example, edit the Administrator group and enable AI Assistant
* The AI will know what you have selected in the Studio left trees. Select a stream and prompt "Analyze this stream, look for issues, tell me how it can be improved".
Post 253 IP   flag post
* More about the AI Assistant and How to Set it up Here
Post 254 IP   flag post
* Multiple GS Query Editor and Tester windows can be open at the same time now
* More AI Assistant improvements
Post 255 IP   flag post
* Allow copy to clipboard from notification lists and job errors
* AI Minion is not used anymore. Leaving configuration for now as it might be used later.
* Fixed AI Document hallucinations (it made beta 1 experience very poor)
* AI Context now directs responses to be more concise/shorter
* GS SQL Docs always loaded now for every AI prompt. The minion's job was to determine if sql docs were to be loaded. It would be wrong sometimes and that would cause a bad user chat experience.
* AI knows when user/system/job notifications are selected and visible: "Tell me how to fix this job issue"
* AI will Expand content folders on left when user asks to Open or Edit content items (components,dashboards, tools) "Edit component Substation Master" "Edit this dashboard" "open this stream"
* Security Group aggregation of capabilities bug fix. Was impacting AIs ability to query notifications for org non-owners
* Improved AI chat scrolling and improved websocket connection management
* Cleared previous contents while refreshing AI dashboard widget
* AI still is not allowed to modify anything
Post 256 IP   flag post
* Error in SQL Grammar docs: STDDEV & STDDEVP renamed to STDEV & STDEVP: The function descriptions were correct and the SQL engine expected STDEV/STDEVP, but the documentation was wrong. The SQL grammar page has been updated.
* Export Stream Data fix for an issue that prevented export if the user chose a custom time range outside the range of any of the selected streams existing range
* Components could not be expanded within the Mobile site fix
* AI Assistant Beta 3
- Added Sub-Agent
- Improved token management
- Improved AI document sources
- Added Stream Correlation detection
- Added the ability to traverse content trees
- Increased prompt size limit
Post 257 IP   flag post
* Added the ability for custom rollups by component. Cycle definitions now have Reference Date Source which can be Use Cycle's or Use Component's. A good use case would be that some monthly reports might be the day of the month the component came online. For this use case, create a Month and Year cycle with Use Component's reference date and have the reference date day be the day the component signed up. Then create a new rollup calendar that uses the two new cycles (plus the standard minute, hour, day cycles) and have the component stream(s) reference that rollup calendar:
* The export window is now available from dashboard widgets. The Select Streams button will not be visible by default. If it is enabled, the dashboard user will be able to browse folders, components, and streams that they have rights to. It is important to have user folder security enabled if you enable the Select Streams button:
* Dashboard users can now select which streams to view within a widget:
Post 258 IP   flag post
* Previous deployment (above) failed. Changes are included in this new deployment:
* AI Assistant Beta 4
- Chat History with "Pinning"
- Improved AI SQL prompts (SQL AI document pre-loading improved)
- Sub Agent Name in all user messages
* Major GS SQL Refactoring
- Improved syntax checking
- Improved alias support for grouping and sorting
- These changes are important for AI as it assumes GS SQL supports common SQL syntax (which it mostly does). When an AI SQL statement fails, AI will adjust the SQL and try again. Adjusting and retrying consume tokens and takes more time. These latest additions decrease AI retries.
* Ensure your SQL Queries are still working. It was a major refactor.
Post 259 IP   flag post
* Fixed GS SQL Semantic check error that occurred when a sample alias was used in the where clause
Post 260 IP   flag post
* Fixed Dashboards using api keys not opening. It was due to new user settings call (for widget stream filtering) not authenticating correctly with api keys.
Post 261 IP   flag post
* Fixed dashboards not appearing while running browser in incognito mode
* Fixed GS SQL sample alias join issues
* Fixed dynamic rollup failing while using component reference date
Post 262 IP   flag post
Temporal Intelligence
Post 263 IP   flag post
* Website static page styling
* Updated LLM Chat agent interfaces.
Post 264 IP   flag post
3071 264 14
