Two new device tutorials:
* GroveStreams STMicroelectronics STM32F746 Discovery - Quick Start
* GroveStreams STMicroelectronics STM32F746 Discovery - Advanced
Post 126 IP   flag post
* Added Enterprise pricing plan
Post 127 IP   flag post
* Added the ability to apply expressions to import values:
Post 128 IP   flag post
* Fixed an issue preventing text boxes, such as the sign-in fields, from getting the focus for touch devices.
Post 129 IP   flag post
* Fixed Stream Group Picker bug: https://forum.grovestreams.com/topic/441/error-setting-interval-stream-aggregation/
* Added Generate Missing IDs for Missing Entities to Organization export wizard:
All exported items must have their IDs set now. The Export logic will set the IDs to random UUIDs if the above is enabled.
* Added Stream ID column to the Stream Import Profile custom import setup
Post 130 IP   flag post
* Added organization user email address and state to the org user manager window.
* Added Re-Invite button to allow admins to send the GS invite email to users in the INVITED state
* Improved error handling around email sending. Email send errors will be reported as an org System Notification
Post 131 IP   flag post
* Added the ability to copy Import Profiles
* We now allow referenced cycles to add new custom time ranges
Post 132 IP   flag post
* The ability to add users to your organization while automatically registering them with GroveStreams. Some OEM'rs were complaining that org invited users were not receiving the GS registration email. We believe this is because some IT shops are blocking emails with web links in them. This feature lets you auto-register users and bypass the registration confirmation email.
An email will still be sent to the user that contains a link (yeah, another link) and their password when the Invite User button is clicked. Mail your users manually if your users still do not receive this automatic email.
Post 133 IP   flag post
* Patch for Dashboard Widgets: https://forum.grovestreams.com/topic/456/component-created-but-error-adding-stream/
* Patch for Editing Delete Profiles: https://forum.grovestreams.com/topic/456/component-created-but-error-adding-stream/
* Patch for Invite Users to Org: Missing Password error was incorrectly raised while inviting existing users.
Post 134 IP   flag post
* Upgraded to Bing Maps v8
* Upgraded Web UI Toolkit to the latest version
* Fixed Pivot table locking and outline bug
* Added IDs to dashboard Widgets, component stream groups, component events, and Action Package Actions
* Changed blueprint logic to use IDs for the above objects instead of hidden UUIDs. Hidden UUIDs had issues that could cause data loss when moving objects back and forth between two organizations
Post 135 IP   flag post
* New Stream Import Format: "gs.importGsStreams". This format is the same file format that Stream Export uses. You can now easily import an exported stream file.
* Organization Backup and Restore Capability:
Post 136 IP   flag post
* Fixed Map Zoom and Map type settings not being retained
* Org Restore Stream sample assignment is now a Job since it can take a long time to run
* Added Reversed setting to dashboard graph axes settings. This reverses the axis order. For example, zero could be the top y-axis number and 10 is below it and 20 is below it and so on.
Post 137 IP   flag post
* Added Treat Nulls As Zero option to derivation settings. See https://forum.grovestreams.com/topic/471/derivation---treat-nulls-as-zero/
Post 138 IP   flag post
* Added Copy functionality to Stream Groups
* Added Start Enabled to Pivot Grid Chart series. This property will start the series hidden, but allow the user to click on the series within the legend to display it.
Post 139 IP   flag post
* Point stream reconcile fix. Reconciling a point stream was clearing its value before the fix.
Post 140 IP   flag post
* Restricted SSL RC4 Ciphers to remain PCI compliant. "A" rating from Qualys SSL Labs:
* This thread hasn't been very active lately. Hang on. There are some nice additions coming.
Post 141 IP   flag post
* Fixed an issue that was preventing new users from registering. The issue was with Google Captcha spam prevention. We've upgraded to their latest "I am not a Robot" library.
* Fixed an issue that impacted certain Feed api calls that started 1 to 2 days ago because of a faulty patch deployment.
Post 142 IP   flag post
* Added the ability to align streams by Start Date within Dashboard Table widget. This setting is significant if a mixture of Interval and Regular streams are being displayed:
* Added Decimal and Thousand separators to the Unit definition. See this thread for more details.
Post 143 IP   flag post
@MikeMills Hi, Captcha is still not working for personalized domain, can you check please ?
Post 144 IP   flag post
@pat - Our sign up panel was messed up. Just checked in a patch for that. Hit F5 to refresh the browser cache and pickup the change.
It looks like, for the new Captcha, we have to register a totally rebranded URL domain with our Google captcha account. If you've totally rebranded your URL, send us an email (support email) with the domain name (i.e. acmestreams.com) and we'll register it.
Post 145 IP   flag post
* Fixed an issue that prevented folder items from being dragged above or below the current viewing range.
Post 146 IP   flag post
* Increased Production Server capacity. Should see shorter derivation runtimes. Monitoring....
Post 147 IP   flag post
* The GroveStreams interaction with our Credit Card service provider is broken. This will prevent GroveStreams from Billing customers temporarily and prevent customers from registering credit cards. The following error could possibly be displayed until we resolve this issue:
javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
Post 148 IP   flag post
Increased production server capacity has made a definite improvement in shorter derivation times! Thank you!!!
Post 149 IP   flag post
@ctmorrison - Thanks! We see the improvement too.
* Non-Impacting restart of all cluster servers while upgrading Java to a newer version today. Our current version of Java did not include the latest crypto libraries needed to interact with our credit card processing company.
Post 150 IP   flag post
* Fixed an issue that could cause pivot table values to double when Refresh was clicked
* Fixed an issue that prevented component streams from appearing within the component tree after editing a component within the studio
Post 151 IP   flag post
Avocadodude private msg quote post Address this user
Anything in the last patch that would cause colorization of Steel Series gauges to stop working? Just happened this morning.
Post 152 IP   flag post
@Avocadodude - Yes. Working on a patch.
Post 153 IP   flag post
@Avocadodude - Patch applied for Steel Series threshold colorization bug. Client-side javascript fix. Hit F5 to clear the old code out of your browser cache and pickup the fix.
Issue caused by an accidental change to old code while working on super secret project.
Post 154 IP   flag post
Never hit send....
The patch is good! Thank you.
Post 155 IP   flag post
3071 264 30
