Latest Changes35
| * Fixed an issue that could cause pivot table values to double when Refresh was clicked * Fixed an issue that prevented component streams from appearing within the component tree after editing a component within the studio |
| Post 151 IP flag post | ||
Avocadodude private msg quote post Address this user | |
| Anything in the last patch that would cause colorization of Steel Series gauges to stop working? Just happened this morning. | ||
| Post 152 IP flag post | ||
| @Avocadodude - Yes. Working on a patch. | ||
| Post 153 IP flag post | ||
| @Avocadodude - Patch applied for Steel Series threshold colorization bug. Client-side javascript fix. Hit F5 to clear the old code out of your browser cache and pickup the fix. Issue caused by an accidental change to old code while working on super secret project. |
| Post 154 IP flag post | ||
| Never hit send.... The patch is good! Thank you. |
| Post 155 IP flag post | ||
| * Fixed an issue that caused the sign-up page to work intermittently; was caused by Captcha "I am not a Robot" integration. | ||
| Post 156 IP flag post | ||
| * Fixed an issue that sometimes prevented map functionality from working. | ||
| Post 157 IP flag post | ||
| * Currently making changes to satisfy EU GDPR. We will update the production site before May 25th which is the GDPR deadline. * If you are a GS OEM'r and have users in the EU, you will also need to satisfy GDPR. You will need to identify GS as a 3rd party data processor. * FYI, by default, new component streams are configured to only retain data for two years. You can change this by entering the org, entering component studio, editing the two year Delete Profile. Rename it and change the time to retain data. |
| Post 158 IP flag post | ||
| * EU GDPR Compliance including updates to our Privacy page. | ||
| Post 159 IP flag post | ||
* Added the ability to query for streams, via stream groups, by the stream's last value by applying an expression to the last value.![]() |
| Post 160 IP flag post | ||
