Shared Dashboard is blank450
seb62085 private msg quote post Address this user
So i give the shared dashboard URL to someone and the website is blank. Same when i open the URL. ANy help?
Scott
I tried to do a couple things to replicate your problem and wasn't able to. Everything I did that was an error popped up some message box or asked for credentials.
Is it possible you didn't save the dashboard first before trying to open the shared link?
Saving is my guess too. We usually report any errors back to the user.
You can use the browser debugger to see if any unreported errors are happening. Use Chrome, Hit F12, and Monitor the debug window Console tab for any errors and report them here if you see any.
kinserc private msg quote post Address this user
Scott,
I had the same problem. I found that my issue was because my browser had no access to 'ajax.googleapis.com'. I am a special case.. I live behind the Great Firewall of China (everything google is filtered). But maybe my problem gives you some insight to solve your problem.
Check your 'hosts' file : C:WindowsSystem32driversetc
3068 4 4
