Component created, but error adding stream456
Avocadodude private msg quote post Address this user
I am trying to help someone get set up on Grovestreams. They had components working, but switched Arduino devices so created new devices/components and deleted old ones. Now the components add correctly but the streams don't. I get a 422 response.
If I manually send the call I get this for every stream:
{"message":"ERROR: 'RRtest/BatteryVoltage': Invalid stream delete profile reference. Missing from store. UID: 61b4747b-e310-306e-a3e4-53845eaf2e5c
I've tried creating new api keys and get same problem.
I created a new organization and it works as expected. I've also tried an api key from my account and it works.
Any thoughts on resetting an organization?
Enter the Organization and select Admin-Organization-General Settings and select a Default Delete Profile.
My guess is the one that had been selected there earlier was deleted and the system isn't handling that scenario properly:
When I try to create a Default delete profile I can create it, but I can't find a way to save it. I've tried in Chrome and Safari thinking it might be browser issue. Am I doing something wrong?
Try increasing the window size. There is a Save and Cancel button at the bottom. I can see them without stretching the window.
OK. Reproduced it. There's a bug. We'll work on a patch.
Thanks for quick response as always. I thought I was needing a new glasses prescription.
Patch applied. Hit F5 to refresh the browser.
3070 7 7
