I need to send a POST command via an event to a Particle device when certain conditions arise. I'm getting an error message that Particle is not seeing the access_token.
When I set up the HTTP action package, I put the appropriate URL in the URL field and put "access_token=9999999999&args=abc" in the body of the POST dialogue.
Here's an excerpt from the Particle docs:
COMPLEMENTARY API CALL
POST /v1/devices/{DEVICE_ID}/{FUNCTION}
# EXAMPLE REQUEST
curl https://api.particle.io/v1/devices/0123456789abcdef/brew
-d access_token=123412341234
-d "args=coffee"
OK...I may have figured it out. From one of your examples, I noticed the "content-type" header being specified and tried it. It appears to have worked. Still testing.....
3063 2 2
