Any way to filter a table?477
orbitcoms private msg quote post Address this user
Is there a method to enable the user to select parameters to filter the data into a table.
For example -> All records over a date range and Specific record types over a date range.
For example, my application will have data from Vehicles that contains the logs of events happening on the vehicle, the data will have a date/time stamp for when the record is created, a Vehicle ID, Type of Event and Event Action ID.
I would like to be able to have a pull down or some control to select a date range, then all or specific vehicle ID and/or event Type and/or Event action ID.
Take a look at the pivot table widget too. It allows for some filtering and sorting.
Filtering can also be done via derived streams. Derive a stream that is a filtered result.
We don't provide a pull down to select the date range directly in a dashboard widget. The range can be selected via the widget edit options.
3068 2 2
