Josephny private msg quote post Address this user
I use code that displays the moving 7 day average propane usage.
Unfortunately, whenever I get a tank fill up, the average gets messed up.
I use this code:
if(isNull(weekagopropane) || isNull(currentpropane), NULL, (weekagopropane-currentpropane)*10)
I tried the following but got an error on column 125 that I can't figure out:
if(isNull(weekagopropane) || isNull(currentpropane) || isNull(dayagopropane), NULL, (if((weekagopropane-currentpropane)<=1) , (dayagopropane-currentpropane)*10,(weekagopropane-currentpropane)*10)
Can someone please help me?
Thanks!
MThomas private msg quote post Address this user
I think you might be missing a parenthese for your very first parenthese.
Try:
if(isNull(weekagopropane) || isNull(currentpropane) || isNull(dayagopropane), NULL, (if((weekagopropane-currentpropane)<=1) , (dayagopropane-currentpropane)*10,(weekagopropane-currentpropane)*10))
Not sure if it helps, but you can plug it into an online Excel Formula Beautifier.
http://excelformulabeautifier.com/
Try:
Thank you for the help.
I tried that and received the following error:
"ERROR: 'Minutes per gallon/7 Days Propane Useage Total n-7': Stream Derivation Expression Error: 'Line 1 column 125: Function com.singularsys.jep.functions.If@5228cc7f: invalid number of arguments 1'."
It doesn't like "<=1"
I tried "<0" and it didn't like that either.
As if it was a type mismatch but from what I read that doesn't apply in this environment.
Cool!
It might not help here (or it might), but it'll definitely help in many other situations.
Thanks!
The error is actually referring to the number of arguments in the "if" statement. I think your parenthesis are still messed up. Try this one
if(
    isNull(weekagopropane) || isNull(currentpropane) ||isNull(dayagopropane),
    NULL,
    if(
        ( weekagopropane - currentpropane ) <= 1,
        ( dayagopropane - currentpropane ) * 10,
        ( weekagopropane - currentpropane ) * 10
That did it!
And I learned how to use formatting to make the code so much more readable and error free!
Thank you!
Well, I thought it worked because I didn't get the immediate error, but there's still a problem:
3034 8 8
