dashboard/graph/settings/data/"apply expression" to stream of binary.510
ero4444 private msg quote post Address this user
how to?
Right now my Zwave contact sensor is reporting the opposite-desired sense (TRUE when fan is OFF). Apparently the sensor has no parameters to adjust this report.
I have worked around it by making a derived stream, 1. but can the "apply expression" above, be used to graph using the original stream instead? 2. I tried "!" "NOT" etc. but I could not figure out what the whole expression should be?
Try:
!value
Use value in the expression for the current sample being processed like these examples:
value + 1
value * 100
if(value,1,0)
if(value,"On", "Off"
Also, if your stream is defined with a Value Type of Boolean, then you can configure a Unit for the stream to display on/off and some other identifiers.
yep that did it.
Thanks - I missed the title in the property box, "!value" works for my purpose.
3067 3 3
