Downloading Data at Different Intervals526
MThomas private msg quote post Address this user
Hi, we are sending data to GS every 15 minutes for a customer and that works great. The customer wants to download their data in 1 minute averages. (Silly I know, because you will just get 15 values of the same value). Anywho, they have requested it, what is the best way to go about this?
1. I would first try this api call (are they using the api?). Pass in the 1 minute cycleID. Try the "first" stat:
GET api/comp/{compId}/cycle/{cycleId}/stat/{statId}/feed
Api Page: https://www.grovestreams.com/developers/api.html#3
2. If that doesn't work, create a new derived stream on the component.
Make it an interval stream
Make its base cycle 1 minute
Derive it "From Expression" and from the 15 minute stream (var1).
Set the expression to: var1
Make sure you set the derivation "Effective Date" to an early enough date.
Then they can download that stream.
If you're new to derived streams. It takes a minute or two to derived. Watch for errors in the notifications Job tab (the envelope in the toolbar).
Hi Mike,
Thanks for the suggestion, I'm attempting to make it work. What do I pass for cycle ID to do 1 minute? When I try 'hour' it works, but when I try 'minute' it fails. Is cycle Id something I need to setup?
Edit: I was able to figure out it's ID is 'min' from the tools section in the GS admin tools. But now I'm getting the following error: {"success":false,"errCode":"REQUEST_VALIDATION_FAILURE","message":"Request Cycle '1 Minute' is not compatible with this stream and its RollupCalendar 'Years, Months, Days, Hours, 5 Minutes, 1 Minute'"}
I tried a derivation interval stream. I kind of got it working but for every minute that isn't a 15 minute interval the data is zero or null. If the value is say 5.0 between 10:15 and 10:30 then how do I get the value at 10:16 to read 5.0 (instead of 0.0)?
There's probably a couple of ways. 1st, try gap filling on the one minute stream. Edit the stream and setup gap filling (gap filling tab).
Thanks Mike, I tried gap filling, but I'm getting the results below:
The minute data in between 15 minutes is blank.
That should've worked.
Gap filling happens as stream data is saved. Did you rerun derivation after you setup gap filling?
To re-derive: Right click on Conc-1Min and select "Delete all time-series data", then wait a couple of minutes for it to re-derive.
Hi Mike,
I re-derived by doing as you said. I could see it cleared all the data and re-derived, but I'm getting the same result:
My API Call Response:
{"data":null,"streamId":"CONC1MIN","time":1592230500000},{"data":null,"streamId":"CONC1MIN","time":1592230440000},{"data":null,"streamId":"CONC1MIN","time":1592230380000},{"data":null,"streamId":"CONC1MIN","time":1592230320000},{"data":null,"streamId":"CONC1MIN","time":1592230260000},{"data":null,"streamId":"CONC1MIN","time":1592230200000},{"data":null,"streamId":"CONC1MIN","time":1592230140000},{"data":null,"streamId":"CONC1MIN","time":1592230080000},{"data":null,"streamId":"CONC1MIN","time":1592230020000},{"data":null,"streamId":"CONC1MIN","time":1592229960000},{"data":null,"streamId":"CONC1MIN","time":1592229900000},{"data":null,"streamId":"CONC1MIN","time":1592229840000},{"data":null,"streamId":"CONC1MIN","time":1592229780000},{"data":null,"streamId":"CONC1MIN","time":1592229720000},{"data":2,"streamId":"CONC1MIN","time":1592229660000},{"data":null,"streamId":"CONC1MIN","time":1592229600000},{"data":null,"streamId":"CONC1MIN","time":1592229540000},{"data":null,"streamId":"CONC1MIN","time":1592229480000},{"data":null,"streamId":"CONC1MIN","time":1592229420000},{"data":null,"streamId":"CONC1MIN","time":1592229360000},{"data":null,"streamId":"CONC1MIN","time":1592229300000},{"data":null,"streamId":"CONC1MIN","time":1592229240000},{"data":null,"streamId":"CONC1MIN","time":1592229180000},{"data":null,"streamId":"CONC1MIN","time":1592229120000},{"data":null,"streamId":"CONC1MIN","time":1592229060000},{"data":null,"streamId":"CONC1MIN","time":1592229000000},{"data":null,"streamId":"CONC1MIN","time":1592228940000},{"data":null,"streamId":"CONC1MIN","time":1592228880000},{"data":null,"streamId":"CONC1MIN","time":1592228820000},{"data":2,"streamId":"CONC1MIN","time":1592228760000},{"data":null,"streamId":"CONC1MIN","time":1592228700000},{"data":null,"streamId":"CONC1MIN","time":1592228640000},{"data":null,"streamId":"CONC1MIN","time":1592228580000},{"data":null,"streamId":"CONC1MIN","time":1592228520000},{"data":null,"streamId":"CONC1MIN","time":1592228460000},{"data":null,"streamId":"CONC1MIN","time":1592228400000},{"data":null,"streamId":"CONC1MIN","time":1592228340000},{"data":null,"streamId":"CONC1MIN","time":1592228280000},{"data":null,"streamId":"CONC1MIN","time":1592228220000},{"data":null,"streamId":"CONC1MIN","time":1592228160000},{"data":null,"streamId":"CONC1MIN","time":1592228100000},{"data":null,"streamId":"CONC1MIN","time":1592228040000},{"data":null,"streamId":"CONC1MIN","time":1592227980000},{"data":null,"streamId":"CONC1MIN","time":1592227920000},{"data":1,"streamId":"CONC1MIN","time":1592227860000},{"data":null,"streamId":"CONC1MIN","time":1592227800000},{"data":null,"streamId":"CONC1MIN","time":1592227740000},{"data":null,"streamId":"CONC1MIN","time":1592227680000},{"data":null,"streamId":"CONC1MIN","time":1592227620000},{"data":null,"streamId":"CONC1MIN","time":1592227560000},{"data":null,"streamId":"CONC1MIN","time":1592227500000},{"data":null,"streamId":"CONC1MIN","time":1592227440000},{"data":null,"streamId":"CONC1MIN","time":1592227380000},{"data":null,"streamId":"CONC1MIN","time":1592227320000},{"data":null,"streamId":"CONC1MIN","time":1592227260000},{"data":null,"streamId":"CONC1MIN","time":1592227200000},{"data":null,"streamId":"CONC1MIN","time":1592227140000},{"data":null,"streamId":"CONC1MIN","time":1592227080000},{"data":null,"streamId":"CONC1MIN","time":1592227020000},{"data":1,"streamId":"CONC1MIN","time":1592226960000},{"data":null,"streamId":"CONC1MIN","time":1592226900000},{"data":null,"streamId":"CONC1MIN","time":1592226840000},{"data":null,"streamId":"CONC1MIN","time":1592226780000},{"data":null,"streamId":"CONC1MIN","time":1592226720000},{"data":null,"streamId":"CONC1MIN","time":1592226660000},{"data":null,"streamId":"CONC1MIN","time":1592226600000},{"data":null,"streamId":"CONC1MIN","time":1592226540000},{"data":null,"streamId":"CONC1MIN","time":1592226480000},{"data":null,"streamId":"CONC1MIN","time":1592226420000},{"data":null,"streamId":"CONC1MIN","time":1592226360000},{"data":null,"streamId":"CONC1MIN","time":1592226300000},{"data":null,"streamId":"CONC1MIN","time":1592226240000},{"data":null,"streamId":"CONC1MIN","time":1592226180000},{"data":null,"streamId":"CONC1MIN","time":1592226120000},{"data":1,"streamId":"CONC1MIN","time":1592226060000},{"data":null,"streamId":"CONC1MIN","time":1592226000000},{"data":null,"streamId":"CONC1MIN","time":1592225940000},{"data":null,"streamId":"CONC1MIN","time":1592225880000},{"data":null,"streamId":"CONC1MIN","time":1592225820000},{"data":null,"streamId":"CONC1MIN","time":1592225760000},{"data":null,"streamId":"CONC1MIN","time":1592225700000},{"data":null,"streamId":"CONC1MIN","time":1592225640000},{"data":null,"streamId":"CONC1MIN","time":1592225580000},{"data":null,"streamId":"CONC1MIN","time":1592225520000},{"data":null,"streamId":"CONC1MIN","time":1592225460000},{"data":null,"streamId":"CONC1MIN","time":1592225400000},{"data":null,"streamId":"CONC1MIN","time":1592225340000},{"data":null,"streamId":"CONC1MIN","time":1592225280000},{"data":null,"streamId":"CONC1MIN","time":1592225220000},{"data":1,"streamId":"CONC1MIN","time":1592225160000},{"data":null,"streamId":"CONC1MIN","time":1592225100000},{"data":null,"streamId":"CONC1MIN","time":1592225040000},{"data":null,"streamId":"CONC1MIN","time":1592224980000},{"data":null,"streamId":"CONC1MIN","time":1592224920000},{"data":null,"streamId":"CONC1MIN","time":1592224860000},{"data":null,"streamId":"CONC1MIN","time":1592224800000},{"data":null,"streamId":"CONC1MIN","time":1592224740000},{"data":null,"streamId":"CONC1MIN","time":1592224680000},{"data":null,"streamId":"CONC1MIN","time":1592224620000},{"data":null,"streamId":"CONC1MIN","time":1592224560000},{"data":null,"streamId":"CONC1MIN","time":1592224500000},{"data":null,"streamId":"CONC1MIN","time":1592224440000},{"data":null,"streamId":"CONC1MIN","time":1592224380000},{"data":null,"streamId":"CONC1MIN","time":1592224320000},{"data":2,"streamId":"CONC1MIN","time":1592224260000},{"data":null,"streamId":"CONC1MIN","time":1592224200000},{"data":null,"streamId":"CONC1MIN","time":1592224140000},{"data":null,"streamId":"CONC1MIN","time":1592224080000},{"data":null,"streamId":"CONC1MIN","time":1592224020000},{"data":null,"streamId":"CONC1MIN","time":1592223960000},{"data":null,"streamId":"CONC1MIN","time":1592223900000},{"data":null,"streamId":"CONC1MIN","time":1592223840000},{"data":null,"streamId":"CONC1MIN","time":1592223780000},{"data":null,"streamId":"CONC1MIN","time":1592223720000},{"data":null,"streamId":"CONC1MIN","time":1592223660000},{"data":null,"streamId":"CONC1MIN","time":1592223600000},{"data":null,"streamId":"CONC1MIN","time":1592223540000},{"data":null,"streamId":"CONC1MIN","time":1592223480000},{"data":null,"streamId":"CONC1MIN","time":1592223420000},{"data":2,"streamId":"CONC1MIN","time":1592223360000},{"data":null,"streamId":"CONC1MIN","time":1592223300000},{"data":null,"streamId":"CONC1MIN","time":1592223240000},{"data":null,"streamId":"CONC1MIN","time":1592223180000},{"data":null,"streamId":"CONC1MIN","time":1592223120000},{"data":null,"streamId":"CONC1MIN","time":1592223060000},{"data":null,"streamId":"CONC1MIN","time":1592223000000},{"data":null,"streamId":"CONC1MIN","time":1592222940000},{"data":null,"streamId":"CONC1MIN","time":1592222880000},{"data":null,"streamId":"CONC1MIN","time":1592222820000},{"data":null,"streamId":"CONC1MIN","time":1592222760000},{"data":null,"streamId":"CONC1MIN","time":1592222700000},{"data":null,"streamId":"CONC1MIN","time":1592222640000},{"data":null,"streamId":"CONC1MIN","time":1592222580000},{"data":null,"streamId":"CONC1MIN","time":1592222520000},{"data":2,"streamId":"CONC1MIN","time":1592222460000},{"data":null,"streamId":"CONC1MIN","time":1592222400000},{"data":null,"streamId":"CONC1MIN","time":1592222340000},{"data":null,"streamId":"CONC1MIN","time":1592222280000},{"data":null,"streamId":"CONC1MIN","time":1592222220000},{"data":null,"streamId":"CONC1MIN","time":1592222160000},{"data":null,"streamId":"CONC1MIN","time":1592222100000},{"data":null,"streamId":"CONC1MIN","time":1592222040000},{"data":null,"streamId":"CONC1MIN","time":1592221980000},{"data":null,"streamId":"CONC1MIN","time":1592221920000},{"data":null,"streamId":"CONC1MIN","time":1592221860000},{"data":null,"streamId":"CONC1MIN","time":1592221800000},{"data":null,"streamId":"CONC1MIN","time":1592221740000},{"data":null,"streamId":"CONC1MIN","time":1592221680000},{"data":null,"streamId":"CONC1MIN","time":1592221620000},{"data":2,"streamId":"CONC1MIN","time":1592221560000},{"data":null,"streamId":"CONC1MIN","time":1592221500000},{"data":null,"streamId":"CONC1MIN","time":1592221440000},{"data":null,"streamId":"CONC1MIN","time":1592221380000},{"data":null,"streamId":"CONC1MIN","time":1592221320000},{"data":null,"streamId":"CONC1MIN","time":1592221260000},{"data":null,"streamId":"CONC1MIN","time":1592221200000},{"data":null,"streamId":"CONC1MIN","time":1592221140000},{"data":null,"streamId":"CONC1MIN","time":1592221080000},{"data":null,"streamId":"CONC1MIN","time":1592221020000},{"data":null,"streamId":"CONC1MIN","time":1592220960000},{"data":null,"streamId":"CONC1MIN","time":1592220900000},{"data":null,"streamId":"CONC1MIN","time":1592220840000},{"data":null,"streamId":"CONC1MIN","time":1592220780000},{"data":null,"streamId":"CONC1MIN","time":1592220720000},{"data":1,"streamId":"CONC1MIN","time":1592220660000},{"data":null,"streamId":"CONC1MIN","time":1592220600000},{"data":null,"streamId":"CONC1MIN","time":1592220540000},{"data":null,"streamId":"CONC1MIN","time":1592220480000},{"data":null,"streamId":"CONC1MIN","time":1592220420000},{"data":null,"streamId":"CONC1MIN","time":1592220360000},{"data":null,"streamId":"CONC1MIN","time":1592220300000},{"data":null,"streamId":"CONC1MIN","time":1592220240000},{"data":null,"streamId":"CONC1MIN","time":1592220180000},{"data":null,"streamId":"CONC1MIN","time":1592220120000},{"data":null,"streamId":"CONC1MIN","time":1592220060000},{"data":null,"streamId":"CONC1MIN","time":1592220000000},{"data":null,"streamId":"CONC1MIN","time":1592219940000},{"data":null,"streamId":"CONC1MIN","time":1592219880000},{"data":null,"streamId":"CONC1MIN","time":1592219820000},{"data":1,"streamId":"CONC1MIN","time":1592219760000},{"data":null,"streamId":"CONC1MIN","time":1592219700000},{"data":null,"streamId":"CONC1MIN","time":1592219640000},{"data":null,"streamId":"CONC1MIN","time":1592219580000},{"data":null,"streamId":"CONC1MIN","time":1592219520000},{"data":null,"streamId":"CONC1MIN","time":1592219460000},{"data":null,"streamId":"CONC1MIN","time":1592219400000},{"data":null,"streamId":"CONC1MIN","time":1592219340000},{"data":null,"streamId":"CONC1MIN","time":1592219280000},{"data":null,"streamId":"CONC1MIN","time":1592219220000},{"data":null,"streamId":"CONC1MIN","time":1592219160000},{"data":null,"streamId":"CONC1MIN","time":1592219100000},{"data":null,"streamId":"CONC1MIN","time":1592219040000},{"data":null,"streamId":"CONC1MIN","time":1592218980000},{"data":null,"streamId":"CONC1MIN","time":1592218920000},{"data":1,"streamId":"CONC1MIN","time":1592218860000},{"data":null,"streamId":"CONC1MIN","time":1592218800000},{"data":null,"streamId":"CONC1MIN","time":1592218740000},{"data":null,"streamId":"CONC1MIN","time":1592218680000},{"data":null,"streamId":"CONC1MIN","time":1592218620000},{"data":null,"streamId":"CONC1MIN","time":1592218560000},{"data":null,"streamId":"CONC1MIN","time":1592218500000},{"data":null,"streamId":"CONC1MIN","time":1592218440000},{"data":null,"streamId":"CONC1MIN","time":1592218380000},{"data":null,"streamId":"CONC1MIN","time":1592218320000},{"data":null,"streamId":"CONC1MIN","time":1592218260000},{"data":null,"streamId":"CONC1MIN","time":1592218200000},{"data":null,"streamId":"CONC1MIN","time":1592218140000},{"data":null,"streamId":"CONC1MIN","time":1592218080000},{"data":null,"streamId":"CONC1MIN","time":1592218020000},{"data":1,"streamId":"CONC1MIN","time":1592217960000},{"data":null,"streamId":"CONC1MIN","time":1592217900000},{"data":null,"streamId":"CONC1MIN","time":1592217840000},{"data":null,"streamId":"CONC1MIN","time":1592217780000},{"data":null,"streamId":"CONC1MIN","time":1592217720000},{"data":null,"streamId":"CONC1MIN","time":1592217660000},{"data":null,"streamId":"CONC1MIN","time":1592217600000},{"data":null,"streamId":"CONC1MIN","time":1592217540000},{"data":null,"streamId":"CONC1MIN","time":1592217480000},{"data":null,"streamId":"CONC1MIN","time":1592217420000},{"data":null,"streamId":"CONC1MIN","time":1592217360000},{"data":null,"streamId":"CONC1MIN","time":1592217300000},{"data":null,"streamId":"CONC1MIN","time":1592217240000},{"data":null,"streamId":"CONC1MIN","time":1592217180000},{"data":null,"streamId":"CONC1MIN","time":1592217120000},{"data":1,"streamId":"CONC1MIN","time":1592217060000},{"data":null,"streamId":"CONC1MIN","time":1592217000000},{"data":null,"streamId":"CONC1MIN","time":1592216940000},{"data":null,"streamId":"CONC1MIN","time":1592216880000},{"data":null,"streamId":"CONC1MIN","time":1592216820000},{"data":null,"streamId":"CONC1MIN","time":1592216760000},{"data":null,"streamId":"CONC1MIN","time":1592216700000},{"data":null,"streamId":"CONC1MIN","time":1592216640000},{"data":null,"streamId":"CONC1MIN","time":1592216580000},{"data":null,"streamId":"CONC1MIN","time":1592216520000},{"data":null,"streamId":"CONC1MIN","time":1592216460000},{"data":null,"streamId":"CONC1MIN","time":1592216400000},{"data":null,"streamId":"CONC1MIN","time":1592216340000},{"data":null,"streamId":"CONC1MIN","time":1592216280000},{"data":null,"streamId":"CONC1MIN","time":1592216220000},{"data":1,"streamId":"CONC1MIN","time":1592216160000},{"data":null,"streamId":"CONC1MIN","time":1592216100000},{"data":null,"streamId":"CONC1MIN","time":1592216040000},{"data":null,"streamId":"CONC1MIN","time":1592215980000},{"data":null,"streamId":"CONC1MIN","time":1592215920000},{"data":null,"streamId":"CONC1MIN","time":1592215860000},{"data":null,"streamId":"CONC1MIN","time":1592215800000},{"data":null,"streamId":"CONC1MIN","time":1592215740000},{"data":null,"streamId":"CONC1MIN","time":1592215680000},{"data":null,"streamId":"CONC1MIN","time":1592215620000},{"data":null,"streamId":"CONC1MIN","time":1592215560000},{"data":null,"streamId":"CONC1MIN","time":1592215500000},{"data":null,"streamId":"CONC1MIN","time":1592215440000},{"data":null,"streamId":"CONC1MIN","time":1592215380000},{"data":null,"streamId":"CONC1MIN","time":1592215320000},{"data":1,"streamId":"CONC1MIN","time":1592215260000},{"data":null,"streamId":"CONC1MIN","time":1592215200000},{"data":null,"streamId":"CONC1MIN","time":1592215140000},{"data":null,"streamId":"CONC1MIN","time":1592215080000},{"data":null,"streamId":"CONC1MIN","time":1592215020000},{"data":null,"streamId":"CONC1MIN","time":1592214960000},{"data":null,"streamId":"CONC1MIN","time":1592214900000},{"data":null,"streamId":"CONC1MIN","time":1592214840000},{"data":null,"streamId":"CONC1MIN","time":1592214780000},{"data":null,"streamId":"CONC1MIN","time":1592214720000},{"data":null,"streamId":"CONC1MIN","time":1592214660000},{"data":null,"streamId":"CONC1MIN","time":1592214600000},{"data":null,"streamId":"CONC1MIN","time":1592214540000},{"data":null,"streamId":"CONC1MIN","time":1592214480000},{"data":null,"streamId":"CONC1MIN","time":1592214420000},{"data":1,"streamId":"CONC1MIN","time":1592214360000},{"data":null,"streamId":"CONC1MIN","time":1592214300000},{"data":null,"streamId":"CONC1MIN","time":1592214240000},{"data":null,"streamId":"CONC1MIN","time":1592214180000},{"data":null,"streamId":"CONC1MIN","time":1592214120000},{"data":null,"streamId":"CONC1MIN","time":1592214060000},{"data":null,"streamId":"CONC1MIN","time":1592214000000},{"data":null,"streamId":"CONC1MIN","time":1592213940000},{"data":null,"streamId":"CONC1MIN","time":1592213880000},{"data":null,"streamId":"CONC1MIN","time":1592213820000},{"data":null,"streamId":"CONC1MIN","time":1592213760000},{"data":null,"streamId":"CONC1MIN","time":1592213700000},{"data":null,"streamId":"CONC1MIN","time":1592213640000},{"data":null,"streamId":"CONC1MIN","time":1592213580000},{"data":null,"streamId":"CONC1MIN","time":1592213520000},{"data":1,"streamId":"CONC1MIN","time":1592213460000},{"data":null,"streamId":"CONC1MIN","time":1592213400000},{"data":null,"streamId":"CONC1MIN","time":1592213340000},{"data":null,"streamId":"CONC1MIN","time":1592213280000},{"data":null,"streamId":"CONC1MIN","time":1592213220000},{"data":null,"streamId":"CONC1MIN","time":1592213160000},{"data":null,"streamId":"CONC1MIN","time":1592213100000},{"data":null,"streamId":"CONC1MIN","time":1592213040000},{"data":null,"streamId":"CONC1MIN","time":1592212980000},{"data":null,"streamId":"CONC1MIN","time":1592212920000},{"data":null,"streamId":"CONC1MIN","time":1592212860000},{"data":null,"streamId":"CONC1MIN","time":1592212800000},{"data":null,"streamId":"CONC1MIN","time":1592212740000},{"data":null,"streamId":"CONC1MIN","time":1592212680000},{"data":null,"streamId":"CONC1MIN","time":1592212620000},{"data":1,"streamId":"CONC1MIN","time":1592212560000},{"data":null,"streamId":"CONC1MIN","time":1592212500000},{"data":null,"streamId":"CONC1MIN","time":1592212440000},{"data":null,"streamId":"CONC1MIN","time":1592212380000},{"data":null,"streamId":"CONC1MIN","time":1592212320000},{"data":null,"streamId":"CONC1MIN","time":1592212260000},{"data":null,"streamId":"CONC1MIN","time":1592212200000},{"data":null,"streamId":"CONC1MIN","time":1592212140000},{"data":null,"streamId":"CONC1MIN","time":1592212080000},{"data":null,"streamId":"CONC1MIN","time":1592212020000},{"data":null,"streamId":"CONC1MIN","time":1592211960000},{"data":null,"streamId":"CONC1MIN","time":1592211900000},{"data":null,"streamId":"CONC1MIN","time":1592211840000},{"data":null,"streamId":"CONC1MIN","time":1592211780000},{"data":null,"streamId":"CONC1MIN","time":1592211720000},{"data":1,"streamId":"CONC1MIN","time":1592211660000},{"data":null,"streamId":"CONC1MIN","time":1592211600000},{"data":null,"streamId":"CONC1MIN","time":1592211540000},{"data":null,"streamId":"CONC1MIN","time":1592211480000},{"data":null,"streamId":"CONC1MIN","time":1592211420000},{"data":null,"streamId":"CONC1MIN","time":1592211360000},{"data":null,"streamId":"CONC1MIN","time":1592211300000},{"data":null,"streamId":"CONC1MIN","time":1592211240000},{"data":null,"streamId":"CONC1MIN","time":1592211180000},{"data":null,"streamId":"CONC1MIN","time":1592211120000},{"data":null,"streamId":"CONC1MIN","time":1592211060000},{"data":null,"streamId":"CONC1MIN","time":1592211000000},{"data":null,"streamId":"CONC1MIN","time":1592210940000},{"data":null,"streamId":"CONC1MIN","time":1592210880000},{"data":null,"streamId":"CONC1MIN","time":1592210820000},{"data":1,"streamId":"CONC1MIN","time":1592210760000},{"data":null,"streamId":"CONC1MIN","time":1592210700000},{"data":null,"streamId":"CONC1MIN","time":1592210640000},{"data":null,"streamId":"CONC1MIN","time":1592210580000},{"data":null,"streamId":"CONC1MIN","time":1592210520000},{"data":null,"streamId":"CONC1MIN","time":1592210460000},{"data":null,"streamId":"CONC1MIN","time":1592210400000},{"data":null,"streamId":"CONC1MIN","time":1592210340000},{"data":null,"streamId":"CONC1MIN","time":1592210280000},{"data":null,"streamId":"CONC1MIN","time":1592210220000},{"data":null,"streamId":"CONC1MIN","time":1592210160000},{"data":null,"streamId":"CONC1MIN","time":1592210100000},{"data":null,"streamId":"CONC1MIN","time":1592210040000},{"data":null,"streamId":"CONC1MIN","time":1592209980000},{"data":null,"streamId":"CONC1MIN","time":1592209920000},{"data":1,"streamId":"CONC1MIN","time":1592209860000},{"data":null,"streamId":"CONC1MIN","time":1592209800000},{"data":null,"streamId":"CONC1MIN","time":1592209740000},{"data":null,"streamId":"CONC1MIN","time":1592209680000},{"data":null,"streamId":"CONC1MIN","time":1592209620000},{"data":null,"streamId":"CONC1MIN","time":1592209560000},{"data":null,"streamId":"CONC1MIN","time":1592209500000},{"data":null,"streamId":"CONC1MIN","time":1592209440000},{"data":null,"streamId":"CONC1MIN","time":1592209380000},{"data":null,"streamId":"CONC1MIN","time":1592209320000},{"data":null,"streamId":"CONC1MIN","time":1592209260000},{"data":null,"streamId":"CONC1MIN","time":1592209200000},{"data":null,"streamId":"CONC1MIN","time":1592209140000},{"data":null,"streamId":"CONC1MIN","time":1592209080000},{"data":null,"streamId":"CONC1MIN","time":1592209020000},{"data":1,"streamId":"CONC1MIN","time":1592208960000},{"data":null,"streamId":"CONC1MIN","time":1592208900000},{"data":null,"streamId":"CONC1MIN","time":1592208840000},{"data":null,"streamId":"CONC1MIN","time":1592208780000},{"data":null,"streamId":"CONC1MIN","time":1592208720000},{"data":null,"streamId":"CONC1MIN","time":1592208660000},{"data":null,"streamId":"CONC1MIN","time":1592208600000},{"data":null,"streamId":"CONC1MIN","time":1592208540000},{"data":null,"streamId":"CONC1MIN","time":1592208480000},{"data":null,"streamId":"CONC1MIN","time":1592208420000},{"data":null,"streamId":"CONC1MIN","time":1592208360000},{"data":null,"streamId":"CONC1MIN","time":1592208300000},{"data":null,"streamId":"CONC1MIN","time":1592208240000},{"data":null,"streamId":"CONC1MIN","time":1592208180000},{"data":null,"streamId":"CONC1MIN","time":1592208120000},{"data":1,"streamId":"CONC1MIN","time":1592208060000},{"data":null,"streamId":"CONC1MIN","time":1592208000000},{"data":null,"streamId":"CONC1MIN","time":1592207940000},{"data":null,"streamId":"CONC1MIN","time":1592207880000},{"data":null,"streamId":"CONC1MIN","time":1592207820000},{"data":null,"streamId":"CONC1MIN","time":1592207760000},{"data":null,"streamId":"CONC1MIN","time":1592207700000},{"data":null,"streamId":"CONC1MIN","time":1592207640000},{"data":null,"streamId":"CONC1MIN","time":1592207580000},{"data":null,"streamId":"CONC1MIN","time":1592207520000},{"data":null,"streamId":"CONC1MIN","time":1592207460000},{"data":null,"streamId":"CONC1MIN","time":1592207400000},{"data":null,"streamId":"CONC1MIN","time":1592207340000},{"data":null,"streamId":"CONC1MIN","time":1592207280000},{"data":null,"streamId":"CONC1MIN","time":1592207220000},{"data":1,"streamId":"CONC1MIN","time":1592207160000},{"data":null,"streamId":"CONC1MIN","time":1592207100000},{"data":null,"streamId":"CONC1MIN","time":1592207040000},{"data":null,"streamId":"CONC1MIN","time":1592206980000},{"data":null,"streamId":"CONC1MIN","time":1592206920000},{"data":null,"streamId":"CONC1MIN","time":1592206860000},{"data":null,"streamId":"CONC1MIN","time":1592206800000},{"data":null,"streamId":"CONC1MIN","time":1592206740000},{"data":null,"streamId":"CONC1MIN","time":1592206680000},{"data":null,"streamId":"CONC1MIN","time":1592206620000},{"data":null,"streamId":"CONC1MIN","time":1592206560000},{"data":null,"streamId":"CONC1MIN","time":1592206500000},{"data":null,"streamId":"CONC1MIN","time":1592206440000},{"data":null,"streamId":"CONC1MIN","time":1592206380000},{"data":null,"streamId":"CONC1MIN","time":1592206320000},{"data":1,"streamId":"CONC1MIN","time":1592206260000},{"data":null,"streamId":"CONC1MIN","time":1592206200000},{"data":null,"streamId":"CONC1MIN","time":1592206140000},{"data":null,"streamId":"CONC1MIN","time":1592206080000},{"data":null,"streamId":"CONC1MIN","time":1592206020000},{"data":null,"streamId":"CONC1MIN","time":1592205960000},{"data":null,"streamId":"CONC1MIN","time":1592205900000},{"data":null,"streamId":"CONC1MIN","time":1592205840000},{"data":null,"streamId":"CONC1MIN","time":1592205780000},{"data":null,"streamId":"CONC1MIN","time":1592205720000},{"data":null,"streamId":"CONC1MIN","time":1592205660000},{"data":null,"streamId":"CONC1MIN","time":1592205600000},{"data":null,"streamId":"CONC1MIN","time":1592205540000},{"data":null,"streamId":"CONC1MIN","time":1592205480000},{"data":null,"streamId":"CONC1MIN","time":1592205420000},{"data":1,"streamId":"CONC1MIN","time":1592205360000},{"data":null,"streamId":"CONC1MIN","time":1592205300000},{"data":null,"streamId":"CONC1MIN","time":1592205240000},{"data":null,"streamId":"CONC1MIN","time":1592205180000},{"data":null,"streamId":"CONC1MIN","time":1592205120000},{"data":null,"streamId":"CONC1MIN","time":1592205060000},{"data":null,"streamId":"CONC1MIN","time":1592205000000},{"data":null,"streamId":"CONC1MIN","time":1592204940000},{"data":null,"streamId":"CONC1MIN","time":1592204880000},{"data":null,"streamId":"CONC1MIN","time":1592204820000},{"data":null,"streamId":"CONC1MIN","time":1592204760000},{"data":null,"streamId":"CONC1MIN","time":1592204700000},{"data":null,"streamId":"CONC1MIN","time":1592204640000},{"data":null,"streamId":"CONC1MIN","time":1592204580000},{"data":null,"streamId":"CONC1MIN","time":1592204520000},{"data":1,"streamId":"CONC1MIN","time":1592204460000},{"data":null,"streamId":"CONC1MIN","time":1592204400000},{"data":null,"streamId":"CONC1MIN","time":1592204340000},{"data":null,"streamId":"CONC1MIN","time":1592204280000},{"data":null,"streamId":"CONC1MIN","time":1592204220000},{"data":null,"streamId":"CONC1MIN","time":1592204160000},{"data":null,"streamId":"CONC1MIN","time":1592204100000},{"data":null,"streamId":"CONC1MIN","time":1592204040000},{"data":null,"streamId":"CONC1MIN","time":1592203980000},{"data":null,"streamId":"CONC1MIN","time":1592203920000},{"data":null,"streamId":"CONC1MIN","time":1592203860000},{"data":null,"streamId":"CONC1MIN","time":1592203800000},{"data":null,"streamId":"CONC1MIN","time":1592203740000},{"data":null,"streamId":"CONC1MIN","time":1592203680000},{"data":null,"streamId":"CONC1MIN","time":1592203620000},{"data":1,"streamId":"CONC1MIN","time":1592203560000},{"data":null,"streamId":"CONC1MIN","time":1592203500000},{"data":null,"streamId":"CONC1MIN","time":1592203440000},{"data":null,"streamId":"CONC1MIN","time":1592203380000},{"data":null,"streamId":"CONC1MIN","time":1592203320000},{"data":null,"streamId":"CONC1MIN","time":1592203260000},{"data":null,"streamId":"CONC1MIN","time":1592203200000},{"data":null,"streamId":"CONC1MIN","time":1592203140000},{"data":null,"streamId":"CONC1MIN","time":1592203080000},{"data":null,"streamId":"CONC1MIN","time":1592203020000},{"data":null,"streamId":"CONC1MIN","time":1592202960000},{"data":null,"streamId":"CONC1MIN","time":1592202900000},{"data":null,"streamId":"CONC1MIN","time":1592202840000},{"data":null,"streamId":"CONC1MIN","time":1592202780000},{"data":null,"streamId":"CONC1MIN","time":1592202720000},{"data":1,"streamId":"CONC1MIN","time":1592202660000},{"data":null,"streamId":"CONC1MIN","time":1592202600000},{"data":null,"streamId":"CONC1MIN","time":1592202540000},{"data":null,"streamId":"CONC1MIN","time":1592202480000},{"data":null,"streamId":"CONC1MIN","time":1592202420000},{"data":null,"streamId":"CONC1MIN","time":1592202360000},{"data":null,"streamId":"CONC1MIN","time":1592202300000},{"data":null,"streamId":"CONC1MIN","time":1592202240000},{"data":null,"streamId":"CONC1MIN","time":1592202180000},{"data":null,"streamId":"CONC1MIN","time":1592202120000},{"data":null,"streamId":"CONC1MIN","time":1592202060000},{"data":null,"streamId":"CONC1MIN","time":1592202000000},{"data":null,"streamId":"CONC1MIN","time":1592201940000},{"data":null,"streamId":"CONC1MIN","time":1592201880000},{"data":null,"streamId":"CONC1MIN","time":1592201820000},{"data":1,"streamId":"CONC1MIN","time":1592201760000},{"data":null,"streamId":"CONC1MIN","time":1592201700000},{"data":null,"streamId":"CONC1MIN","time":1592201640000},{"data":null,"streamId":"CONC1MIN","time":1592201580000},{"data":null,"streamId":"CONC1MIN","time":1592201520000},{"data":null,"streamId":"CONC1MIN","time":1592201460000},{"data":null,"streamId":"CONC1MIN","time":1592201400000},{"data":null,"streamId":"CONC1MIN","time":1592201340000},{"data":null,"streamId":"CONC1MIN","time":1592201280000},{"data":null,"streamId":"CONC1MIN","time":1592201220000},{"data":null,"streamId":"CONC1MIN","time":1592201160000},{"data":null,"streamId":"CONC1MIN","time":1592201100000},{"data":null,"streamId":"CONC1MIN","time":1592201040000},{"data":null,"streamId":"CONC1MIN","time":1592200980000},{"data":null,"streamId":"CONC1MIN","time":1592200920000},{"data":1,"streamId":"CONC1MIN","time":1592200860000},{"data":null,"streamId":"CONC1MIN","time":1592200800000},{"data":null,"streamId":"CONC1MIN","time":1592200740000},{"data":null,"streamId":"CONC1MIN","time":1592200680000},{"data":null,"streamId":"CONC1MIN","time":1592200620000},{"data":null,"streamId":"CONC1MIN","time":1592200560000},{"data":null,"streamId":"CONC1MIN","time":1592200500000},{"data":null,"streamId":"CONC1MIN","time":1592200440000},{"data":null,"streamId":"CONC1MIN","time":1592200380000},{"data":null,"streamId":"CONC1MIN","time":1592200320000},{"data":null,"streamId":"CONC1MIN","time":1592200260000},{"data":null,"streamId":"CONC1MIN","time":1592200200000},{"data":null,"streamId":"CONC1MIN","time":1592200140000},{"data":null,"streamId":"CONC1MIN","time":1592200080000},{"data":null,"streamId":"CONC1MIN","time":1592200020000},{"data":1,"streamId":"CONC1MIN","time":1592199960000},{"data":null,"streamId":"CONC1MIN","time":1592199900000},{"data":null,"streamId":"CONC1MIN","time":1592199840000},{"data":null,"streamId":"CONC1MIN","time":1592199780000},{"data":null,"streamId":"CONC1MIN","time":1592199720000},{"data":null,"streamId":"CONC1MIN","time":1592199660000},{"data":null,"streamId":"CONC1MIN","time":1592199600000},{"data":null,"streamId":"CONC1MIN","time":1592199540000},{"data":null,"streamId":"CONC1MIN","time":1592199480000},{"data":null,"streamId":"CONC1MIN","time":1592199420000},{"data":null,"streamId":"CONC1MIN","time":1592199360000},{"data":null,"streamId":"CONC1MIN","time":1592199300000},{"data":null,"streamId":"CONC1MIN","time":1592199240000},{"data":null,"streamId":"CONC1MIN","time":1592199180000},{"data":null,"streamId":"CONC1MIN","time":1592199120000},{"data":1,"streamId":"CONC1MIN","time":1592199060000},{"data":null,"streamId":"CONC1MIN","time":1592199000000},{"data":null,"streamId":"CONC1MIN","time":1592198940000},{"data":null,"streamId":"CONC1MIN","time":1592198880000},{"data":null,"streamId":"CONC1MIN","time":1592198820000},{"data":null,"streamId":"CONC1MIN","time":1592198760000},{"data":null,"streamId":"CONC1MIN","time":1592198700000},{"data":null,"streamId":"CONC1MIN","time":1592198640000},{"data":null,"streamId":"CONC1MIN","time":1592198580000},{"data":null,"streamId":"CONC1MIN","time":1592198520000},{"data":null,"streamId":"CONC1MIN","time":1592198460000},{"data":null,"streamId":"CONC1MIN","time":1592198400000},{"data":null,"streamId":"CONC1MIN","time":1592198340000},{"data":null,"streamId":"CONC1MIN","time":1592198280000},{"data":null,"streamId":"CONC1MIN","time":1592198220000},{"data":1,"streamId":"CONC1MIN","time":1592198160000},{"data":null,"streamId":"CONC1MIN","time":1592198100000},{"data":null,"streamId":"CONC1MIN","time":1592198040000},{"data":null,"streamId":"CONC1MIN","time":1592197980000},{"data":null,"streamId":"CONC1MIN","time":1592197920000},{"data":null,"streamId":"CONC1MIN","time":1592197860000},{"data":null,"streamId":"CONC1MIN","time":1592197800000},{"data":null,"streamId":"CONC1MIN","time":1592197740000},{"data":null,"streamId":"CONC1MIN","time":1592197680000},{"data":null,"streamId":"CONC1MIN","time":1592197620000},{"data":null,"streamId":"CONC1MIN","time":1592197560000},{"data":null,"streamId":"CONC1MIN","time":1592197500000},{"data":null,"streamId":"CONC1MIN","time":1592197440000},{"data":null,"streamId":"CONC1MIN","time":1592197380000},{"data":null,"streamId":"CONC1MIN","time":1592197320000},{"data":1,"streamId":"CONC1MIN","time":1592197260000},{"data":null,"streamId":"CONC1MIN","time":1592197200000},{"data":null,"streamId":"CONC1MIN","time":1592197140000},{"data":null,"streamId":"CONC1MIN","time":1592197080000},{"data":null,"streamId":"CONC1MIN","time":1592197020000},{"data":null,"streamId":"CONC1MIN","time":1592196960000},{"data":null,"streamId":"CONC1MIN","time":1592196900000},{"data":null,"streamId":"CONC1MIN","time":1592196840000},{"data":null,"streamId":"CONC1MIN","time":1592196780000},{"data":null,"streamId":"CONC1MIN","time":1592196720000},{"data":null,"streamId":"CONC1MIN","time":1592196660000},{"data":null,"streamId":"CONC1MIN","time":1592196600000},{"data":null,"streamId":"CONC1MIN","time":1592196540000},{"data":null,"streamId":"CONC1MIN","time":1592196480000},{"data":null,"streamId":"CONC1MIN","time":1592196420000},{"data":1,"streamId":"CONC1MIN","time":1592196360000},{"data":null,"streamId":"CONC1MIN","time":1592196300000},{"data":null,"streamId":"CONC1MIN","time":1592196240000},{"data":null,"streamId":"CONC1MIN","time":1592196180000},{"data":null,"streamId":"CONC1MIN","time":1592196120000},{"data":null,"streamId":"CONC1MIN","time":1592196060000},{"data":null,"streamId":"CONC1MIN","time":1592196000000},{"data":null,"streamId":"CONC1MIN","time":1592195940000},{"data":null,"streamId":"CONC1MIN","time":1592195880000},{"data":null,"streamId":"CONC1MIN","time":1592195820000},{"data":null,"streamId":"CONC1MIN","time":1592195760000},{"data":null,"streamId":"CONC1MIN","time":1592195700000},{"data":null,"streamId":"CONC1MIN","time":1592195640000},{"data":null,"streamId":"CONC1MIN","time":1592195580000},{"data":null,"streamId":"CONC1MIN","time":1592195520000},{"data":1,"streamId":"CONC1MIN","time":1592195460000},{"data":null,"streamId":"CONC1MIN","time":1592195400000},{"data":null,"streamId":"CONC1MIN","time":1592195340000},{"data":null,"streamId":"CONC1MIN","time":1592195280000},{"data":null,"streamId":"CONC1MIN","time":1592195220000},{"data":null,"streamId":"CONC1MIN","time":1592195160000},{"data":null,"streamId":"CONC1MIN","time":1592195100000},{"data":null,"streamId":"CONC1MIN","time":1592195040000},{"data":null,"streamId":"CONC1MIN","time":1592194980000},{"data":null,"streamId":"CONC1MIN","time":1592194920000},{"data":null,"streamId":"CONC1MIN","time":1592194860000},{"data":null,"streamId":"CONC1MIN","time":1592194800000},{"data":null,"streamId":"CONC1MIN","time":1592194740000},{"data":null,"streamId":"CONC1MIN","time":1592194680000},{"data":null,"streamId":"CONC1MIN","time":1592194620000},{"data":1,"streamId":"CONC1MIN","time":1592194560000},{"data":null,"streamId":"CONC1MIN","time":1592194500000},{"data":null,"streamId":"CONC1MIN","time":1592194440000},{"data":null,"streamId":"CONC1MIN","time":1592194380000},{"data":null,"streamId":"CONC1MIN","time":1592194320000},{"data":null,"streamId":"CONC1MIN","time":1592194260000},{"data":null,"streamId":"CONC1MIN","time":1592194200000},{"data":null,"streamId":"CONC1MIN","time":1592194140000},{"data":null,"streamId":"CONC1MIN","time":1592194080000},{"data":null,"streamId":"CONC1MIN","time":1592194020000},{"data":null,"streamId":"CONC1MIN","time":1592193960000},{"data":null,"streamId":"CONC1MIN","time":1592193900000},{"data":null,"streamId":"CONC1MIN","time":1592193840000},{"data":null,"streamId":"CONC1MIN","time":1592193780000},{"data":null,"streamId":"CONC1MIN","time":1592193720000},{"data":1,"streamId":"CONC1MIN","time":1592193660000},{"data":null,"streamId":"CONC1MIN","time":1592193600000},{"data":null,"streamId":"CONC1MIN","time":1592193540000},{"data":null,"streamId":"CONC1MIN","time":1592193480000},{"data":null,"streamId":"CONC1MIN","time":1592193420000},{"data":null,"streamId":"CONC1MIN","time":1592193360000},{"data":null,"streamId":"CONC1MIN","time":1592193300000},{"data":null,"streamId":"CONC1MIN","time":1592193240000},{"data":null,"streamId":"CONC1MIN","time":1592193180000},{"data":null,"streamId":"CONC1MIN","time":1592193120000},{"data":null,"streamId":"CONC1MIN","time":1592193060000},{"data":null,"streamId":"CONC1MIN","time":1592193000000},{"data":null,"streamId":"CONC1MIN","time":1592192940000},{"data":null,"streamId":"CONC1MIN","time":1592192880000},{"data":null,"streamId":"CONC1MIN","time":1592192820000},{"data":1,"streamId":"CONC1MIN","time":1592192760000},{"data":null,"streamId":"CONC1MIN","time":1592192700000},{"data":null,"streamId":"CONC1MIN","time":1592192640000},{"data":null,"streamId":"CONC1MIN","time":1592192580000},{"data":null,"streamId":"CONC1MIN","time":1592192520000},{"data":null,"streamId":"CONC1MIN","time":1592192460000},{"data":null,"streamId":"CONC1MIN","time":1592192400000},{"data":null,"streamId":"CONC1MIN","time":1592192340000},{"data":null,"streamId":"CONC1MIN","time":1592192280000},{"data":null,"streamId":"CONC1MIN","time":1592192220000},{"data":null,"streamId":"CONC1MIN","time":1592192160000},{"data":null,"streamId":"CONC1MIN","time":1592192100000},{"data":null,"streamId":"CONC1MIN","time":1592192040000},{"data":null,"streamId":"CONC1MIN","time":1592191980000},{"data":null,"streamId":"CONC1MIN","time":1592191920000},{"data":1,"streamId":"CONC1MIN","time":1592191860000},{"data":null,"streamId":"CONC1MIN","time":1592191800000},{"data":null,"streamId":"CONC1MIN","time":1592191740000},{"data":null,"streamId":"CONC1MIN","time":1592191680000},{"data":null,"streamId":"CONC1MIN","time":1592191620000},{"data":null,"streamId":"CONC1MIN","time":1592191560000},{"data":null,"streamId":"CONC1MIN","time":1592191500000},{"data":null,"streamId":"CONC1MIN","time":1592191440000},{"data":null,"streamId":"CONC1MIN","time":1592191380000},{"data":null,"streamId":"CONC1MIN","time":1592191320000},{"data":null,"streamId":"CONC1MIN","time":1592191260000},{"data":null,"streamId":"CONC1MIN","time":1592191200000},{"data":null,"streamId":"CONC1MIN","time":1592191140000},{"data":null,"streamId":"CONC1MIN","time":1592191080000},{"data":null,"streamId":"CONC1MIN","time":1592191020000},{"data":1,"streamId":"CONC1MIN","time":1592190960000},{"data":null,"streamId":"CONC1MIN","time":1592190900000},{"data":null,"streamId":"CONC1MIN","time":1592190840000},{"data":null,"streamId":"CONC1MIN","time":1592190780000},{"data":null,"streamId":"CONC1MIN","time":1592190720000},{"data":null,"streamId":"CONC1MIN","time":1592190660000},{"data":null,"streamId":"CONC1MIN","time":1592190600000},{"data":null,"streamId":"CONC1MIN","time":1592190540000},{"data":null,"streamId":"CONC1MIN","time":1592190480000},{"data":null,"streamId":"CONC1MIN","time":1592190420000},{"data":null,"streamId":"CONC1MIN","time":1592190360000},{"data":null,"streamId":"CONC1MIN","time":1592190300000},{"data":null,"streamId":"CONC1MIN","time":1592190240000},{"data":null,"streamId":"CONC1MIN","time":1592190180000},{"data":null,"streamId":"CONC1MIN","time":1592190120000},{"data":1,"streamId":"CONC1MIN","time":1592190060000},{"data":null,"streamId":"CONC1MIN","time":1592190000000},{"data":null,"streamId":"CONC1MIN","time":1592189940000},{"data":null,"streamId":"CONC1MIN","time":1592189880000},{"data":null,"streamId":"CONC1MIN","time":1592189820000},{"data":null,"streamId":"CONC1MIN","time":1592189760000},{"data":null,"streamId":"CONC1MIN","time":1592189700000},{"data":null,"streamId":"CONC1MIN","time":1592189640000},{"data":null,"streamId":"CONC1MIN","time":1592189580000},{"data":null,"streamId":"CONC1MIN","time":1592189520000},{"data":null,"streamId":"CONC1MIN","time":1592189460000},{"data":null,"streamId":"CONC1MIN","time":1592189400000},{"data":null,"streamId":"CONC1MIN","time":1592189340000},{"data":null,"streamId":"CONC1MIN","time":1592189280000},{"data":null,"streamId":"CONC1MIN","time":1592189220000},{"data":1,"streamId":"CONC1MIN","time":1592189160000},{"data":null,"streamId":"CONC1MIN","time":1592189100000},{"data":null,"streamId":"CONC1MIN","time":1592189040000},{"data":null,"streamId":"CONC1MIN","time":1592188980000},{"data":null,"streamId":"CONC1MIN","time":1592188920000},{"data":null,"streamId":"CONC1MIN","time":1592188860000},{"data":null,"streamId":"CONC1MIN","time":1592188800000},{"data":null,"streamId":"CONC1MIN","time":1592188740000},{"data":null,"streamId":"CONC1MIN","time":1592188680000},{"data":null,"streamId":"CONC1MIN","time":1592188620000},{"data":null,"streamId":"CONC1MIN","time":1592188560000},{"data":null,"streamId":"CONC1MIN","time":1592188500000},{"data":null,"streamId":"CONC1MIN","time":1592188440000},{"data":null,"streamId":"CONC1MIN","time":1592188380000},{"data":null,"streamId":"CONC1MIN","time":1592188320000},{"data":1,"streamId":"CONC1MIN","time":1592188260000},{"data":null,"streamId":"CONC1MIN","time":1592188200000},{"data":null,"streamId":"CONC1MIN","time":1592188140000},{"data":null,"streamId":"CONC1MIN","time":1592188080000},{"data":null,"streamId":"CONC1MIN","time":1592188020000},{"data":null,"streamId":"CONC1MIN","time":1592187960000},{"data":null,"streamId":"CONC1MIN","time":1592187900000},{"data":null,"streamId":"CONC1MIN","time":1592187840000},{"data":null,"streamId":"CONC1MIN","time":1592187780000},{"data":null,"streamId":"CONC1MIN","time":1592187720000},{"data":null,"streamId":"CONC1MIN","time":1592187660000},{"data":null,"streamId":"CONC1MIN","time":1592187600000},{"data":null,"streamId":"CONC1MIN","time":1592187540000},{"data":null,"streamId":"CONC1MIN","time":1592187480000},{"data":null,"streamId":"CONC1MIN","time":1592187420000},{"data":1,"streamId":"CONC1MIN","time":1592187360000},{"data":null,"streamId":"CONC1MIN","time":1592187300000},{"data":null,"streamId":"CONC1MIN","time":1592187240000},{"data":null,"streamId":"CONC1MIN","time":1592187180000},{"data":null,"streamId":"CONC1MIN","time":1592187120000},{"data":null,"streamId":"CONC1MIN","time":1592187060000},{"data":null,"streamId":"CONC1MIN","time":1592187000000},{"data":null,"streamId":"CONC1MIN","time":1592186940000},{"data":null,"streamId":"CONC1MIN","time":1592186880000},{"data":null,"streamId":"CONC1MIN","time":1592186820000},{"data":null,"streamId":"CONC1MIN","time":1592186760000},{"data":null,"streamId":"CONC1MIN","time":1592186700000},{"data":null,"streamId":"CONC1MIN","time":1592186640000},{"data":null,"streamId":"CONC1MIN","time":1592186580000},{"data":null,"streamId":"CONC1MIN","time":1592186520000},{"data":1,"streamId":"CONC1MIN","time":1592186460000},{"data":null,"streamId":"CONC1MIN","time":1592186400000},{"data":null,"streamId":"CONC1MIN","time":1592186340000},{"data":null,"streamId":"CONC1MIN","time":1592186280000},{"data":null,"streamId":"CONC1MIN","time":1592186220000},{"data":null,"streamId":"CONC1MIN","time":1592186160000},{"data":null,"streamId":"CONC1MIN","time":1592186100000},{"data":null,"streamId":"CONC1MIN","time":1592186040000},{"data":null,"streamId":"CONC1MIN","time":1592185980000},{"data":null,"streamId":"CONC1MIN","time":1592185920000},{"data":null,"streamId":"CONC1MIN","time":1592185860000},{"data":null,"streamId":"CONC1MIN","time":1592185800000},{"data":null,"streamId":"CONC1MIN","time":1592185740000},{"data":null,"streamId":"CONC1MIN","time":1592185680000},{"data":null,"streamId":"CONC1MIN","time":1592185620000},{"data":1,"streamId":"CONC1MIN","time":1592185560000},{"data":null,"streamId":"CONC1MIN","time":1592185500000},{"data":null,"streamId":"CONC1MIN","time":1592185440000},{"data":null,"streamId":"CONC1MIN","time":1592185380000},{"data":null,"streamId":"CONC1MIN","time":1592185320000},{"data":null,"streamId":"CONC1MIN","time":1592185260000},{"data":null,"streamId":"CONC1MIN","time":1592185200000},{"data":null,"streamId":"CONC1MIN","time":1592185140000},{"data":null,"streamId":"CONC1MIN","time":1592185080000},{"data":null,"streamId":"CONC1MIN","time":1592185020000},{"data":null,"streamId":"CONC1MIN","time":1592184960000},{"data":null,"streamId":"CONC1MIN","time":1592184900000},{"data":null,"streamId":"CONC1MIN","time":1592184840000},{"data":null,"streamId":"CONC1MIN","time":1592184780000},{"data":null,"streamId":"CONC1MIN","time":1592184720000},{"data":1,"streamId":"CONC1MIN","time":1592184660000},{"data":null,"streamId":"CONC1MIN","time":1592184600000},{"data":null,"streamId":"CONC1MIN","time":1592184540000},{"data":null,"streamId":"CONC1MIN","time":1592184480000},{"data":null,"streamId":"CONC1MIN","time":1592184420000},{"data":null,"streamId":"CONC1MIN","time":1592184360000},{"data":null,"streamId":"CONC1MIN","time":1592184300000},{"data":null,"streamId":"CONC1MIN","time":1592184240000},{"data":null,"streamId":"CONC1MIN","time":1592184180000},{"data":null,"streamId":"CONC1MIN","time":1592184120000},{"data":null,"streamId":"CONC1MIN","time":1592184060000},{"data":null,"streamId":"CONC1MIN","time":1592184000000},{"data":null,"streamId":"CONC1MIN","time":1592183940000},{"data":null,"streamId":"CONC1MIN","time":1592183880000},{"data":null,"streamId":"CONC1MIN","time":1592183820000},{"data":1,"streamId":"CONC1MIN","time":1592183760000},{"data":null,"streamId":"CONC1MIN","time":1592183700000},{"data":null,"streamId":"CONC1MIN","time":1592183640000},{"data":null,"streamId":"CONC1MIN","time":1592183580000},{"data":null,"streamId":"CONC1MIN","time":1592183520000},{"data":null,"streamId":"CONC1MIN","time":1592183460000},{"data":null,"streamId":"CONC1MIN","time":1592183400000},{"data":null,"streamId":"CONC1MIN","time":1592183340000},{"data":null,"streamId":"CONC1MIN","time":1592183280000},{"data":null,"streamId":"CONC1MIN","time":1592183220000},{"data":null,"streamId":"CONC1MIN","time":1592183160000},{"data":null,"streamId":"CONC1MIN","time":1592183100000},{"data":null,"streamId":"CONC1MIN","time":1592183040000},{"data":null,"streamId":"CONC1MIN","time":1592182980000},{"data":null,"streamId":"CONC1MIN","time":1592182920000},{"data":1,"streamId":"CONC1MIN","time":1592182860000},{"data":null,"streamId":"CONC1MIN","time":1592182800000},{"data":null,"streamId":"CONC1MIN","time":1592182740000},{"data":null,"streamId":"CONC1MIN","time":1592182680000},{"data":null,"streamId":"CONC1MIN","time":1592182620000},{"data":null,"streamId":"CONC1MIN","time":1592182560000},{"data":null,"streamId":"CONC1MIN","time":1592182500000},{"data":null,"streamId":"CONC1MIN","time":1592182440000},{"data":null,"streamId":"CONC1MIN","time":1592182380000},{"data":null,"streamId":"CONC1MIN","time":1592182320000},{"data":null,"streamId":"CONC1MIN","time":1592182260000},{"data":null,"streamId":"CONC1MIN","time":1592182200000},{"data":null,"streamId":"CONC1MIN","time":1592182140000},{"data":null,"streamId":"CONC1MIN","time":1592182080000},{"data":null,"streamId":"CONC1MIN","time":1592182020000},{"data":1,"streamId":"CONC1MIN","time":1592181960000},{"data":null,"streamId":"CONC1MIN","time":1592181900000},{"data":null,"streamId":"CONC1MIN","time":1592181840000},{"data":null,"streamId":"CONC1MIN","time":1592181780000},{"data":null,"streamId":"CONC1MIN","time":1592181720000},{"data":null,"streamId":"CONC1MIN","time":1592181660000},{"data":null,"streamId":"CONC1MIN","time":1592181600000},{"data":null,"streamId":"CONC1MIN","time":1592181540000},{"data":null,"streamId":"CONC1MIN","time":1592181480000},{"data":null,"streamId":"CONC1MIN","time":1592181420000},{"data":null,"streamId":"CONC1MIN","time":1592181360000},{"data":null,"streamId":"CONC1MIN","time":1592181300000},{"data":null,"streamId":"CONC1MIN","time":1592181240000},{"data":null,"streamId":"CONC1MIN","time":1592181180000},{"data":null,"streamId":"CONC1MIN","time":1592181120000},{"data":1,"streamId":"CONC1MIN","time":1592181060000},{"data":null,"streamId":"CONC1MIN","time":1592181000000},{"data":null,"streamId":"CONC1MIN","time":1592180940000},{"data":null,"streamId":"CONC1MIN","time":1592180880000},{"data":null,"streamId":"CONC1MIN","time":1592180820000},{"data":null,"streamId":"CONC1MIN","time":1592180760000},{"data":null,"streamId":"CONC1MIN","time":1592180700000},{"data":null,"streamId":"CONC1MIN","time":1592180640000},{"data":null,"streamId":"CONC1MIN","time":1592180580000},{"data":null,"streamId":"CONC1MIN","time":1592180520000},{"data":null,"streamId":"CONC1MIN","time":1592180460000},{"data":null,"streamId":"CONC1MIN","time":1592180400000},{"data":null,"streamId":"CONC1MIN","time":1592180340000},{"data":null,"streamId":"CONC1MIN","time":1592180280000},{"data":null,"streamId":"CONC1MIN","time":1592180220000},{"data":1,"streamId":"CONC1MIN","time":1592180160000},{"data":null,"streamId":"CONC1MIN","time":1592180100000},{"data":null,"streamId":"CONC1MIN","time":1592180040000},{"data":null,"streamId":"CONC1MIN","time":1592179980000},{"data":null,"streamId":"CONC1MIN","time":1592179920000},{"data":null,"streamId":"CONC1MIN","time":1592179860000},{"data":null,"streamId":"CONC1MIN","time":1592179800000},{"data":null,"streamId":"CONC1MIN","time":1592179740000},{"data":null,"streamId":"CONC1MIN","time":1592179680000},{"data":null,"streamId":"CONC1MIN","time":1592179620000},{"data":null,"streamId":"CONC1MIN","time":1592179560000},{"data":null,"streamId":"CONC1MIN","time":1592179500000},{"data":null,"streamId":"CONC1MIN","time":1592179440000},{"data":null,"streamId":"CONC1MIN","time":1592179380000},{"data":null,"streamId":"CONC1MIN","time":1592179320000},{"data":1,"streamId":"CONC1MIN","time":1592179260000},{"data":null,"streamId":"CONC1MIN","time":1592179200000},{"data":null,"streamId":"CONC1MIN","time":1592179140000},{"data":null,"streamId":"CONC1MIN","time":1592179080000},{"data":null,"streamId":"CONC1MIN","time":1592179020000},{"data":null,"streamId":"CONC1MIN","time":1592178960000},{"data":null,"streamId":"CONC1MIN","time":1592178900000},{"data":null,"streamId":"CONC1MIN","time":1592178840000},{"data":null,"streamId":"CONC1MIN","time":1592178780000},{"data":null,"streamId":"CONC1MIN","time":1592178720000},{"data":null,"streamId":"CONC1MIN","time":1592178660000},{"data":null,"streamId":"CONC1MIN","time":1592178600000},{"data":null,"streamId":"CONC1MIN","time":1592178540000},{"data":null,"streamId":"CONC1MIN","time":1592178480000},{"data":null,"streamId":"CONC1MIN","time":1592178420000},{"data":1,"streamId":"CONC1MIN","time":1592178360000},{"data":null,"streamId":"CONC1MIN","time":1592178300000},{"data":null,"streamId":"CONC1MIN","time":1592178240000},{"data":null,"streamId":"CONC1MIN","time":1592178180000},{"data":null,"streamId":"CONC1MIN","time":1592178120000},{"data":null,"streamId":"CONC1MIN","time":1592178060000},{"data":null,"streamId":"CONC1MIN","time":1592178000000},{"data":null,"streamId":"CONC1MIN","time":1592177940000},{"data":null,"streamId":"CONC1MIN","time":1592177880000},{"data":null,"streamId":"CONC1MIN","time":1592177820000},{"data":null,"streamId":"CONC1MIN","time":1592177760000},{"data":null,"streamId":"CONC1MIN","time":1592177700000},{"data":null,"streamId":"CONC1MIN","time":1592177640000},{"data":null,"streamId":"CONC1MIN","time":1592177580000},{"data":null,"streamId":"CONC1MIN","time":1592177520000},{"data":1,"streamId":"CONC1MIN","time":1592177460000},{"data":null,"streamId":"CONC1MIN","time":1592177400000},{"data":null,"streamId":"CONC1MIN","time":1592177340000},{"data":null,"streamId":"CONC1MIN","time":1592177280000},{"data":null,"streamId":"CONC1MIN","time":1592177220000},{"data":null,"streamId":"CONC1MIN","time":1592177160000},{"data":null,"streamId":"CONC1MIN","time":1592177100000},{"data":null,"streamId":"CONC1MIN","time":1592177040000},{"data":null,"streamId":"CONC1MIN","time":1592176980000},{"data":null,"streamId":"CONC1MIN","time":1592176920000},{"data":null,"streamId":"CONC1MIN","time":1592176860000},{"data":null,"streamId":"CONC1MIN","time":1592176800000},{"data":null,"streamId":"CONC1MIN","time":1592176740000},{"data":null,"streamId":"CONC1MIN","time":1592176680000},{"data":null,"streamId":"CONC1MIN","time":1592176620000},{"data":1,"streamId":"CONC1MIN","time":1592176560000},{"data":null,"streamId":"CONC1MIN","time":1592176500000},{"data":null,"streamId":"CONC1MIN","time":1592176440000},{"data":null,"streamId":"CONC1MIN","time":1592176380000},{"data":null,"streamId":"CONC1MIN","time":1592176320000},{"data":null,"streamId":"CONC1MIN","time":1592176260000},{"data":null,"streamId":"CONC1MIN","time":1592176200000},{"data":null,"streamId":"CONC1MIN","time":1592176140000},{"data":null,"streamId":"CONC1MIN","time":1592176080000},{"data":null,"streamId":"CONC1MIN","time":1592176020000},{"data":null,"streamId":"CONC1MIN","time":1592175960000},{"data":null,"streamId":"CONC1MIN","time":1592175900000},{"data":null,"streamId":"CONC1MIN","time":1592175840000},{"data":null,"streamId":"CONC1MIN","time":1592175780000},{"data":null,"streamId":"CONC1MIN","time":1592175720000},{"data":1,"streamId":"CONC1MIN","time":1592175660000},{"data":null,"streamId":"CONC1MIN","time":1592175600000},{"data":null,"streamId":"CONC1MIN","time":1592175540000},{"data":null,"streamId":"CONC1MIN","time":1592175480000},{"data":null,"streamId":"CONC1MIN","time":1592175420000},{"data":null,"streamId":"CONC1MIN","time":1592175360000},{"data":null,"streamId":"CONC1MIN","time":1592175300000},{"data":null,"streamId":"CONC1MIN","time":1592175240000},{"data":null,"streamId":"CONC1MIN","time":1592175180000},{"data":null,"streamId":"CONC1MIN","time":1592175120000},{"data":null,"streamId":"CONC1MIN","time":1592175060000},{"data":null,"streamId":"CONC1MIN","time":1592175000000},{"data":null,"streamId":"CONC1MIN","time":1592174940000},{"data":null,"streamId":"CONC1MIN","time":1592174880000},{"data":null,"streamId":"CONC1MIN","time":1592174820000},{"data":1,"streamId":"CONC1MIN","time":1592174760000},{"data":null,"streamId":"CONC1MIN","time":1592174700000},{"data":null,"streamId":"CONC1MIN","time":1592174640000},{"data":null,"streamId":"CONC1MIN","time":1592174580000},{"data":null,"streamId":"CONC1MIN","time":1592174520000},{"data":null,"streamId":"CONC1MIN","time":1592174460000},{"data":null,"streamId":"CONC1MIN","time":1592174400000},{"data":null,"streamId":"CONC1MIN","time":1592174340000},{"data":null,"streamId":"CONC1MIN","time":1592174280000},{"data":null,"streamId":"CONC1MIN","time":1592174220000}]
Any other suggestions?
Try setting Max Continuous Gaps to Fill to something bigger than zero on the Gap Filling Tab. See if that is the issue.
The re-run derivation.
Thank Mike, that fixed it. They are 15 minute samples, so I set the max to 15.
Mike,
Is there a way to get it to update the stream every minute? It seems it doesn't fill in the gap data until the 15 minute sample comes in. So if I download data at 1:44, I only get all the data up to 1:30.
Can't think of another way today except for having the device upload every minute.
Gap Filling only fills gaps as data comes in.
We're working on a solution that will gap fill as data is queried for, but that will not be available for months.
3039 14 14
