How to get an alert if door is opened for more than 45 seconds ?527
I don't see how I could used derived stream, latency event or other to get an alert if my door is opened for more than 45 seconds, any help ?
I receive a 1 each time the door is open and a 0 each time it is closed.
How can I set an alert if I don't receive a 0 within 45 seconds from the last 1 received ?
Thank you
You will have to user derived streams and get a derived stream to derive automatically at the current time.
See this thread:
https://forum.grovestreams.com/topic/494/gap-filling-forward-to-current-time/
Also search for "kicker" in the forum.
Your logic can compare the source stream for a 1 and track the SAMPLE_TIME. Then use time()-SAMPLE_TIME to get the number of milliseconds that have passed. Setup an event/alert on the derived stream.
This won't get you an alert at the 45 sec mark, but you should get one within 3 minutes since derivation runs 2-3 minute cycles.
3070 2 2
