is there way to show dot for point display of stream value on line chart?546
ero4444 private msg quote post Address this user
I see how to show the label, which has an approximate position where I want to see a dot in the line for that stream. A dot would be a little better to show the actual position.
I have temperature streams with infrequent updates, so often I don't have two values in one stream chart duration to draw an actual line on my typical chart/graph, so that line becomes invisible.
We haven't exposed the marker radius setting. But, if you set the series line width to zero, the marker becomes visible.
Does that help?
sure, that gives me an usually-visible option. Thanks.
The new dashboard designer supports this.
Demonstrates it around 4:30
3070 4 4
