Surprising addition to gauges556
JChristensen private msg quote post Address this user
After editing a gauge on a dashboard (adjusted the range), then viewing the dashboard, I see what I suppose is an indicator light. Sometimes it flashes. It is not visible while editing and I cannot determine the setting to turn it off. It is not visible on unedited dashboards. I tried the following settings, to no avail:
Threshold Rising: false
Trend Visible: false
Threshold Indicator: 0
Threshold Indicator Visible: false
Threshold Warn Eval: (blank)
Threshold Max Eval: (blank)
The setting is ledVisible and it seems to be true for you, but we removed that setting for that widget. It defaults to false when the gauge is displayed and it can't be edited. It's odd that you're seeing it.
I can't reproduce this.
You're using the new dashboard Editor and not the old one (or the old MOBILE one)? Right click on the dashboard and choose Edit to be sure you're using the new one.
Try clearing your browser cache (Chrome Ctrl-Refresh button). The new dashboard designer doesn't require doing this, but it won't hurt to try.
3068 2 2
